Old 04-07-2012, 08:46 AM   #5651 (permalink)
Hey Paul!
I received the 500 amp controller two days after you shipped it, however I am just getting around to checking it out. Very well packaged. Thansk for shipping it so fast.
Had a couple of questions. As far as I can tell, the green led was the only thing missing. I am placing an order to mouser for some other items anyway and wanted to ask if the 859-LTL-307G (green LED, mouser part #) is the correct one to use. I can't see having you ship a 20 cent part, it would cost more to ship than the part is worth.
Second question: If I wanted to make all my connections to the control board using connectors (I know you said earlier that soldering the wires to the board is more reliable), what connector (plug, socket and pins) would you use for J1 on the control board? I am not going to use a connector for G1 - G10 or PH 1 and PH2. That might cause some problems.
Thanks again for the kit!!
Jim B.
Old 04-07-2012, 09:50 AM   #5652 (permalink)
PaulH
MPaulHolmes's Avatar
That's disturbing about the LED. All I do is order the same set of components each time for the control board. It's a saved cart. That means Mouser is trying to pull a fast one. Those stinkers. I really don't mind sending you one. Maybe I should stop trusting that I'm getting everything I order.
I would use this part for a connector on J1:
I would use this part! Isn't it cool that you can have regular writing be the hyperlink?!
kits and boards
Old 04-07-2012, 10:19 AM   #5653 (permalink)
It's no big deal. I've ordered from Jameco and Digikey in the past and they forgot to put all the parts in (like ordering 25 of something and only get 24). It happens!
Thanks for the connector info. I can probably find the female connector, but do you have a number for the pins?
Jim B.
Old 04-07-2012, 11:53 AM   #5654 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
The 1000 Amp Diesel/Electric Plug-In Hybrid Pickup Truck is just WAITING for one of those controllers!
Planning on driving it around like Michigan on less than one tank of bio-diesel/veggie oil.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-09-2012, 11:15 PM   #5655 (permalink)
paul, you should have a motor sometime wednesday, i dropped it at fedex today but it was after the cut-off so it won't ship till tomorrow. i used the address u gave me earlier. i also put in a controller so you can test it if you want to. the controller takes a 60 hz pulse, with a 1mS - 2mS pulse width. the brown wire should gets grounded, and the red wire should be connected to 5 volts. the yellow (or maybe orange) wire is the signal wire. i have limited the amplitude of the pulse signal to like 2 volts on the board i built for controlling mine.
i'm controlling mine with a board built out of a pair of 555 timers, but a function generator should work perfectly for bench testing. if you use a 2Vpp pulse, offset it by 1 volt positive so the bottom of it looks like ground.
The Following User Says Thank You to isaac_alaska For This Useful Post:
MPaulHolmes (04-10-2012)
Old 04-10-2012, 09:07 AM   #5656 (permalink)
PaulH
Dear Michael Holmes,
Your order is dispatched Apr 10, 2012 by FedEX....
We delivered following items:
Part Number: ACControlBoard Quantity: 10
Part Number: ACHighSideDriverBoard Quantity: 10
Part Number: ACLowSideDriverBoard Quantity: 10
Part Number: ACPowerBoard Quantity: 5
Part Number: DCControlBoard Quantity: 10
Part Number: DCDriverBoard Quantity: 10
Part Number: DCPowerBoard Quantity: 5
Thank you for the order.
HURRAY!!!
kits and boards
The Following 4 Users Say Thank You to MPaulHolmes For This Useful Post:
adamj12b (04-10-2012), LouMan (04-10-2012), rayjay (04-10-2012), zsnemeth (04-10-2012)
Old 04-10-2012, 03:09 PM   #5657 (permalink)
rev2c controller in service!
Hey Paul, wanted to let you know that I am officially running a cougar controller in my '96 saturn conversion. Drove a 24v on-street test run today and have been using it at 12v to pull into the shop for several weeks. It's working so now i guess i have to finish this car! Without your controller project I probably would not have done this conversion - Thank You.
The Following 2 Users Say Thank You to ChedMpls For This Useful Post:
MPaulHolmes (04-10-2012), mpgmike (01-22-2022)
Old 04-10-2012, 03:23 PM   #5658 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Cool to hear there's another one in service. Post photos!
My YouTube Videos
Old 04-10-2012, 03:27 PM   #5659 (permalink)
dave koller's Avatar
Hey like to see some shots of the car as I have a 99 SL2 ---
Dave ...
Old 04-11-2012, 08:07 PM   #5660 (permalink)
Paul,
I have been going through the 500 Amp controller kit you sent me and went to the wiki to get the schematic. I assume I have the Rev 2D kit and the schematics for it are no longer available. I do have a schematic for Rev 2B and Rev 2C. Could you tell me what changes were made from Rev 2C to Rev 2D? Or is the schematic entirely different for Rev 2D?
Oh, I ordered the green LED for the control board so don't send it!
Thanks,
Jim
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
