Old 07-07-2014, 05:10 PM   #6631 (permalink)
EV Connoisseur
So I have a logic analyser.. and I'm looking at this HIN202 diagram.. but I'm confused on were I should be able to pickup ttl uart on that chip.. and gnd..
Is there a schema available? that would help.
Old 07-07-2014, 05:13 PM   #6632 (permalink)
EV Connoisseur
I'm guessing it must be 12 & 11 and 15 for GND
Old 07-07-2014, 05:20 PM   #6633 (permalink)
EV Connoisseur
I'm catching my input at ttl level on pin 12, but there is no response on 11:
Old 07-07-2014, 05:23 PM   #6634 (permalink)
EV Connoisseur
Just because it looks cool, my setup:
The Following User Says Thank You to flores For This Useful Post:
MPaulHolmes (07-16-2014)
Old 07-07-2014, 05:23 PM   #6635 (permalink)
PaulH
MPaulHolmes's Avatar
Yep, that's right. I'm trying to find my serial to usb connector at the moment, and then I'll check the serial. I've tested the serial, and then I made a bunch of changes for actually using it in the golf cart, and I need to see if I disabled some serial comm from the micro. I was testing each part separately before. Well, the search for my cable now continues. I don't think I have the commands echoing to the screen. Let me see what is going on. I'll be back soon.
kits and boards
Old 07-07-2014, 05:24 PM   #6636 (permalink)
EV Connoisseur
Paul, could it not work because all my inputs are disconnected?
Old 07-07-2014, 05:28 PM   #6637 (permalink)
EV Connoisseur
Just tested if it gives something on boot.. but nothing
Old 07-07-2014, 05:39 PM   #6638 (permalink)
PaulH
aha!!! Yes. It's not getting to the serial communications code, because there is no throttle present, so it's just freezing until a valid throttle is present. You shouldn't need any other inputs connected.
kits and boards
Old 07-07-2014, 05:45 PM   #6639 (permalink)
EV Connoisseur
Check!
Connected the throttle wires together.. and now I hear the relays..
And on boot it says:
The Stinky Diaper firmware, ver. 1.0
But it still does not respond to the config command, should it?
Old 07-07-2014, 05:55 PM   #6640 (permalink)
PaulH
I'm checking now. Well, in like 5 minutes, because this laptop doesn't have realterm on it, and I must download it.
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
