03-01-2018, 02:26 PM
#7231 (permalink)
Originally Posted by jackbauer
Are the schematics and layout files available anywhere? Most of the links on the Wiki seem dead.
Last time I looked the files for AC were available on Paul's github
https://github.com/MPaulHolmes?tab=repositories
I don't see the PCB etc for the IGBT version of the DC controller. My board is older and I know it's not the latest and greatest. I can PM you the files I have ... not sure if Paul wants to try to support them though.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following 2 Users Say Thank You to thingstodo For This Useful Post:
03-02-2018, 03:55 AM
#7232 (permalink)
Thanks, I think I actually found the files on my pc but if you could pm me what you have that would be great
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
03-02-2018, 09:07 AM
#7233 (permalink)
I'll add this to my todo for tonight. More copies stored on more computers = good!
03-02-2018, 09:09 AM
#7234 (permalink)
If you can get me the files, I can upload them to the EM server so they'll be there forevah! No more broken links.
03-02-2018, 09:59 AM
#7235 (permalink)
OK - I'll send you a copy as well. But you realize that these are not the latest and greatest .. right?
03-02-2018, 10:22 AM
#7236 (permalink)
Something is better than nothing I suppose.
03-04-2018, 12:54 AM
#7237 (permalink)
PCB, SCH, and source that I have
This is the latest I have
I was not able to figure out how to do attachments on PMs
So here's what I have
The Following User Says Thank You to thingstodo For This Useful Post:
03-04-2018, 03:37 AM
#7238 (permalink)
Is this the 144v 500A controller or the newer one?
www.evbmw.com
03-04-2018, 10:59 AM
#7239 (permalink)
This is the IGBT version, so the newer one. It looks a lot like the AC controller .. there are 3 IGBTs .. but the outputs are in parallel and the current sensing is done as a group and not for each. It does high side switching for the DC motor instead of low side. If you tie the other motor lead to the +DC bus instead of the -DC bus, the controller does not appear to work.
Paul has been calling one of them Diahrea (I think it's the DC one), and Stinky diaper is, I think, the AC one. A marketing disaster if ever I saw one .. but they are his designs!
03-04-2018, 11:01 AM
#7240 (permalink)
Ok thanks. Is there any info on the old 500A logic board?
www.evbmw.com
