View Poll Results: Which one should I buy with all this money?
Scan Gauge II 7 29.17%
KiwiMPG 0 0%
Rear Tires 15 62.50%
More-than-likely needed tune-up 2 8.33%
Voters: 24. You may not vote on this poll
Old 09-26-2009, 10:53 PM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 28.73 mpg (US)
POLL: This is a bad idea I know...
I just realized with all the money I'm making now that I can afford a SG2... I kind of wanted the KiwiMPG more though.... But as you guys know, I still need rear tires (lol) So poll which one you think I should get, comment too if you have any info about the kiwimpg, some say they are great, some say they are totally off...
Old 09-26-2009, 11:03 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
RandomFact314 -
I voted rear tires. I'm a safety monkey.
CarloSW2
American Solar Energy Society
Old 09-26-2009, 11:11 PM   #3 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I vote rear tires and a tune up
Old 09-27-2009, 01:40 AM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Def rear tires and a tune up... The SG2 can wait.
Old 09-27-2009, 01:03 PM   #5 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Depending on how long you have to save for new tires, I would get the SG2 and then buy two cheap tires with your next paycheck. Then you can see if they were costing you MPGs - an extra experiment!
I don't know how bad your tires are though; if they are really rotten it's a pretty clear safety issue.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 09-27-2009, 01:13 PM   #6 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I'm for routine maintenance first.
You can probably find some steals on used tires, if you want to save some cash there.
Also, if you get the SG, you'll be looking at the numbers telling yourself, "Man, I really need a tune-up!"
Maybe you can hook up an inexpensive Vac-Gauge for some feedback in the meantime.
Best FE to ya...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 09-27-2009, 01:37 PM   #7 (permalink)
I'm not changing my vote, here, but check out CL - you can usually get Neon tires extremely cheap, because they're a fairly common size. If you can get a pair of tires that will last you through the winter and part of next spring, for like $50 or something close, add in $30 to mount/balance them at Wally World, so for about $80 you can have decent tires. The tune up is just a matter of some 0w30 oil, a Neon SRT-4 Filter, and some plugs.. that should cost about $50 total, no need to really buy wires if you're not experiencing arc'ing or sputtering.
So you can have your tune-up for the same price as a good pair of new tires, and probably still have enough money to get the SG2 next week.
You also may be able to get a pair of used tires from a garage for free, if you ask around. I've done this before, too.
Old 09-27-2009, 08:12 PM   #8 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I vote for four used tires, of the same brand and the same remaining treadlife. Some tires grip better in the wet than others, some grip better on dry.
Front snow tires and rear summer tires = oversteer in snow, understeer on dry pavement. Front summer, rear snow = same problem.
Old 10-05-2009, 08:10 PM   #9 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Vote for maintenance first
BUT; you could go for Auto Meter 9100 Fuel Economy Gauge Ecometer: ATM-9100 Summit Racing Equipment
Much cheaper than SGII, but many less functions. . . . .
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 10-05-2009, 08:41 PM   #10 (permalink)
Cycling more to drive les
White 'rolla - '05 Toyota Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
Tires, tune-up, then get the scan gauge.
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
Civic - Bad in the snow? Daox Off-Topic Tech 51 03-08-2013 11:46 AM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
POLL: Should I make this trade?!? RandomFact314 EcoModding Central 24 09-02-2009 07:02 PM
New hair brained idea... TheTopher EcoModding Central 20 08-27-2008 11:42 PM
