10-08-2020, 06:14 PM
#21 (permalink)
I would say that with wide availability of LTO batteries (practically unlimited cycle life), this is now obviously the case. If you run a small LiFePO4-graphite pack empty everyday, your battery costs are going to be horrible because that battery pack will be gone in a few years. Batteries need to get 2x cheaper and 2x more dense before gasoline unequivocally loses.
My parents leased an X5 40e which could go around 13 miles on the 9.2kWh battery, maybe 15 if you took it easy and went slow. An overnight charge from 110V was enough to fill it up. On a more efficient small sedan instead of a giant boxy behemoth, 25-30 miles of range would be easily achievable.
10-08-2020, 06:34 PM
#22 (permalink)
EcoModding Newb
Interesting, I hadn't read up on LTO before. It appears they are about 2/3 as energy dense as other lithium-ion chemistries.
Since they can be rapidly charged, it should allow vehicles to have smaller batteries since they can accept a high rate of charge equally as well (or better) as a larger capacity lithium-ion battery.
Most interesting is they perform better in temperature extremes; something other chemistries, LiFePO4 in particular struggle with. It may be possible to forego all but the most basic of battery conditioning.
.jpg)
The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by menacing it with an endless series of hobgoblins, all of them imaginary. -H.L Mencken.
10-08-2020, 06:45 PM
#23 (permalink)
AKA - Jason
Originally Posted by cRiPpLe_rOoStEr
Even though I wouldn't hold my breath for the average Joe to embrace the hybrid truck bandwagon so quickly, it would undeniably become a sensible option for business operators and fleet managers. On a sidenote, when GM released hybrid versions for the Silverado and Sierra 1500 and for the Tahoe, Escalade and Yukon it did surprise me they retained a V8 instead of using the Vortec 4300 which used to be standard in the Silverado and Sierra 1500.
In 2019 FCA sold 105,676 eTorque 48V hybrid vehicles between the Ram 1500 and Jeep Wrangler. I would say that is pretty good for the first year.
10-08-2020, 06:50 PM
#24 (permalink)
EcoModding Newb
Yeah, but mild hybrid. The main savings is engine start/stop.
10-08-2020, 10:24 PM
#25 (permalink)
AKA - Jason
Yes, it is a mild-hybrid system but one that Ram truck and Jeep buyers are OK with buying. It is also more than a start / stop system. The electric motor adds 50 lb-ft of torque - way more than needed for a stop / start system.
At the end of the day it is a cheap way to gain 10-12% in fuel economy.
The Following User Says Thank You to JSH For This Useful Post:
10-08-2020, 11:08 PM
#26 (permalink)
Yup, they've actually been in use for a long time in small devices due to their reliability (e.g. the Citizen EcoDrive uses one, they're pretty confident you can keep the watch in the dark draining itself and it won't be an issue). The cycle life is almost comparable to lithium-ion supercapacitors, which is pretty crazy.
From the specs, it seems like the Lotus Evija uses them, as well as a number of other cars. You just can't get continuous 20C discharge rates out of a LFP reliably.
Since it works in the cold, it's also the perfect lead acid starter battery replacement. 5 of them in series gives you 13V at a full charge, very similar to 6 lead acid cells.
10-09-2020, 02:35 AM
#27 (permalink)
Even though a mild-hybrid setup as such already qualifies to benefits in some regions, and recently sparked some controversy at least in Spain where Toyota tried to lobby for the General Traffic Directorate (DGT - Dirección General de Tráfico) to grant an exemption from traffic restrictions in Madrid and Barcelona only for full-hybrids, there is not too many fanfare around it. In export markets such as Brazil, many people got quite surprised once they find out the Wrangler is now available locally only as a hybrid.
