Old 07-03-2010, 04:46 PM   #11 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
If you got 90 with half the tank being "learning", I would probably make my baseline 100.
Old 07-05-2010, 08:00 AM   #12 (permalink)
It takes some practice to get this bike off from a light at a speed that does not frustrate other drivers. More like a WOT drag race, but to be expected when you are pushing 500 pounds with 12 horsepower.
Nice thing around here is many of the roads have bike paths on the shoulder, so you have an additional escape route if someone swerves into your lane.
I have had it to 62 MPH on a flat stretch, which seems to be about as fast as it will go. Very toss able with excellent brakes. Drove over 240 miles over the last 3 days. By the end of today I will probably get another fuel refill to see what the mileage looks like.
Thinking about selling the Insight and keeping this bike and my VX. Haven't driven the Insight in a week.
Funny thing is it seems like people are less prone to tailgating you on a bike. Maybe it's 6feet and 205 pounds, and the snow white goatee that gives them the impression that some respect might be appropriate.
Loads of fun and so far not even a single close encounter of the moron kind. I guess my driving techniques are a factor, since I already assumed stupidity was the norm on the roads around here.
Its fun to cruise at lower speeds. Coasting still works fine when the light ahead is red, but I think pulse and glide is a waste with the aero drag. Other bikers seem to think I will abandon the Kawa for a bigger bike shortly, but after driving the Insight and VX for over 55,000 miles, I am getting used to lower levels of acceleration, and the changes in driving technique you must employ when you can't just mash the gas and blast out of harms way.
New battery, oil change, headlight adjustment, and the power is improving as I get used to the dynamics of a small displacement engine.
Think I'll go wax the painted surfaces .
regards
Mech
Old 07-09-2010, 05:35 AM   #13 (permalink)
90mpg, on a 125cc, whilst learning thats great.
*Checked picture of it*
I want one.
And only with a shade over 15hp too(according to wiki).. Impressive.
Old 08-10-2010, 05:11 PM   #14 (permalink)
NinFo - '09 kawasaki ninja 250R
yeah, eliminator 125s are great. i am getting one in the spring for my commuter. my vulcan 500 isnt bad, but it could be better. its still fast though.
Old 09-29-2015, 11:22 PM   #15 (permalink)
I got about the same results on my MC-05-127 (essentially also a 125cc).
60MPH tops, and the choke can be used to ride it in the correct A/F ratio, or run it leaner or richer.
I got 120MPG out of mine once, but acceleration sucked.
Then I switched back to a bigger rear sprocket, and the Roketa bike had a good 105MPG constant (save for longer highway rides).
The rokkie only has 4 gears tho...
My rebel 250 also gets 80MPG stock with 50% highway top speed, and 95MPG without. Stock sprockets on the Rebel are 14/33t I believe. I run a 15/25t. about as low as one can go.
If I put a 15/27 or 15/26t sprocket, I can achieve higher top speeds, but I'm content with how it rides with a 15/25 in 5th (rides butter smooth between 35-42MPH).
They have a BBK for the eliminator. A 175cc kit, that can gain 5-10MPH; is more efficient and should get you very similar MPG results, because it's lighter weight aluminum, piston and smaller tolerances..
Slowed down - picked up 2+ mpg!!! Bullockracing Success Stories 7 06-05-2009 11:03 AM
Picked up a 98 Saab 9000 CSE... JohnnyGrey EcoModding Central 5 03-02-2009 07:19 PM
Just picked up an '89 metro!!! SirKeats DIY / How-to 4 05-18-2008 02:46 PM
Trash picked Fixey! soon to be EV lovemysan Alternative Transportation 12 04-05-2008 10:53 AM
wow, picked up 2mpg out of nowhere malibuguy EcoModding Central 23 03-01-2008 01:20 AM
