Old 01-07-2021, 04:52 PM   #71 (permalink)
"But easy enough to vacuum pressure form."
http://www.ckdeluxe.com/wp-content/u.../1045-edit.jpg
Check out the M00N Saturn disks. ....and the frontal area.
edit: I just found that I'd saved this an album, a ventilated M00N disk.
You can't be wise and in love at the same time. -- Bob Dylan
aerohead (01-08-2021)
Old 01-08-2021, 09:41 AM   #72 (permalink)
You don't usually mold canopies because the plastic optically exaggerates any defect a mold has. I believe the term is called free form and uses plates to restrict only the attachment edges. Everthing else is done with gravity and heat, sometimes air pressure aka blowmolding.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
aerohead (01-08-2021), Xist (04-24-2021)
Old 01-08-2021, 11:49 AM   #73 (permalink)
True. A circular plate can give optical quality. A male or female slump form would have to be near-perfect or it will show any imperfection as the wheel rotates.
I'd go with aluminum, else paint a spiral on it.
Xist (04-24-2021)
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Moon Disc Hubcaps vs Insight Wheels 1337 Aerodynamics 42 12-18-2008 02:03 PM
For Sale: Moon Hubcaps for 14" rims swoody For Sale 10 12-03-2008 05:10 PM
14" Moon Hubcaps, trade for 15"? or sell for cash Sean T. For Sale 2 09-17-2008 04:17 PM
Solid wheel caps (moon discs - where to get?) NoCO2 Aerodynamics 48 02-12-2008 05:23 PM
