Old 09-26-2008, 04:28 PM   #1 (permalink)
Red Beast - '82 Honda V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 Honda CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Dodge Neon SXT
90 day: 28.71 mpg (US)
POC vs. Out of gear coasting
I have recently added a MPGuino to my vehicle and have noticed that the mileage when taking the car out of gear is around 130 or so but the gauge tops out if I leave it in gear with the accelerator off or just slightly on.
Has anybody else noticed this?
I understand the concept. Fuel is required to keep the engine running if it is not in gear. However, I have not seen this mentioned anywhere. I suppose that you need an Econometer that shows instant MPG to be able to get the sweet spot.
Old 09-26-2008, 05:18 PM   #2 (permalink)
ptsmith24's Avatar
El Camrino - '90 Toyota Camry LE
90 day: 32.47 mpg (US)
Yea, fuel cut off. I found mine is around 55mph (~1800RPM in that gear). I found it using the MPGuino in my car. Although it isn't calibrated (sorta close, but still too far to do any good), it goes from 31MPG at 55MPH to 38-40MPG after releasing the throttle. I'll try and keep that in mind if I ever P&G eventually.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Old 09-26-2008, 07:27 PM   #3 (permalink)
There seems to be a sweet spot on the throttle where there is little or no fuel being delivered and you don't loose speed. This is the point I was wondering about.
Old 09-26-2008, 08:44 PM   #4 (permalink)
90 day: 51.82 mpg (US)
Well, you can't be using no fuel and still maintain speed (unless you're going downhill or being towed!), but you're right in noticing that you can often feather the throttle back to an absolute minimum and maintain your current speed.
I've read a few times when people get instant fuel consumption displays how surprised they are at how relatively minor throttle position changes can have relatively big MPG changes.
Old 09-26-2008, 08:45 PM   #5 (permalink)
PS: what's "POC"?
Old 09-26-2008, 09:52 PM   #6 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
I think it means "pedal off coast" or coasting in gear with your foot off the pedal.
I think that you are better off coasting in neutral. It is true that in gear with your foot off the gas, you can use zero fuel (if you're above a certain RPM and your vehicle has a fuel injector cutoff feature), whereas coasting out of gear uses a little fuel to keep the engine running. But you lose speed faster in gear, and based on my observations, you end up using more fuel on the other end when you have to speed up again.
Old 09-27-2008, 03:19 AM   #7 (permalink)
Hasbro's Avatar
Especially when your tires are at 70 psi!
Old 10-02-2008, 04:20 PM   #8 (permalink)
Petal off coast
or
Power off coast (Same thing.) Yes that is what I meant.
Going down hills I can POC and maintain speed. (Handy for my particular commute.) I think that I will keep it in gear and find the 'sweet spot' for maintaining speed. I have been comparing numbers on my MPGuino and at 60mph, it is a tossup (Neutral vs. feathered.)
Old 10-02-2008, 05:25 PM   #9 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
DFCO - we've talked about it a lot.
I get the results I do with NO dfco usage. I'm always using neutral instead. Usually the engine is off, but in certain cases I leave it on.
Old 10-02-2008, 06:48 PM   #10 (permalink)
the shoe - '97 Honda Civic CX
90 day: 28.2 mpg (US)
How much more MPG would you estimate that gives you?
HHINLA
coasting, poc
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 10:39 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
Out of gear coasting safety tasdrouille Hypermiling / EcoDriver's Ed 42 09-25-2008 07:18 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
