Old 06-23-2019, 05:39 PM   #81 (permalink)
Ecomodding Apprentice
From how it increases I'd say around 105-7 but not too concerned about it anymore. Any work just means more money. The rear doors are heavy, around 15kg I would say without the glass and winder motors. Will see my mot guy about making fake doors
Also on the wheel note carbon versions of mine are only 2kg lighter. Prius wheel were made light for toyota. However I might look into milled ones, they don't need to be as strong as stock ones. I've also looked into adjustable suspension for motorway but it's too heavy
The Following User Says Thank You to Nathan jones For This Useful Post:
TexasCotton (07-10-2019)
Old 06-23-2019, 05:45 PM   #82 (permalink)
Out the mold. Lots to do. It's not as strong as I'd like so will put on another layer on the back and put on mounting stuff
Old 06-25-2019, 05:30 PM   #83 (permalink)
The x y axis was superb but twists. I did some off axis layers but not enough. solid now. Also I wasn't sure the original was designed in conjunction with crumple zones
Also to someone mentioned trying out stuff as a newbie. If I had a second start order lots of 300g glass fibre and polyester resin and make things around the home, get the feel of mixes, cure times, wetting out and corner/flat panel strenths. It will help you get the lightest designs, more brackets and shapes.
I wasted 20m of carbon and epoxy to begin with. Finding your own preferences and the best way to achieve what you want and building your confidence
The Following 2 Users Say Thank You to Nathan jones For This Useful Post:
mpgmike (05-13-2022), TexasCotton (07-10-2019)
Old 06-25-2019, 05:33 PM   #84 (permalink)
The bonnets 1 1/2 inches longer. Some changes to aerodynamics but not big changes. Will need filling and sanding.... ...
Old 07-10-2019, 01:03 AM   #85 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Fuel/Petrol
Nathan hope all is well
I am curious what grade petrol/gasoline do you currently use in your Prius and is pure unleaded petrol /gasoline and ethanol free.
Old 07-24-2019, 07:23 PM   #86 (permalink)
Hey texas c. Fine, thanks for asking. Making another bonnet, new hinge brackets molded off the first one, and a new rear lower glass section thats lighter than the first one..
Regular 95. I've not tried higher octanes..yet
ID:	26507   Click image for larger version
Old 07-24-2019, 07:25 PM   #87 (permalink)
The first one was lumpy and 3kg, too heavy. Carbon went on the cardboard but I've since made a way to use paper
redpoint5 (07-24-2019)
Old 07-24-2019, 07:28 PM   #88 (permalink)
Mirror camera, it will get another layer and trimmed
Drifter (04-10-2022), redpoint5 (07-24-2019)
Old 07-24-2019, 07:30 PM   #89 (permalink)
And it got sprayed..although I used casting resin watered down with brake cleaner as a lacquer so it probably weighs 600g too much
Wont scratch and uv proof
Old 07-24-2019, 07:31 PM   #90 (permalink)
90 day: 43.3 mpg (US)
I wish I were brave enough to work with CF of FG. I tried once, it kicked my butt, and I gave up. Usually what I do when I'm not instantly decent at something.
I tried to take a mould of a kitchen sink for a concrete countertop project, but I must have used too much catalyst so it firmed up way before I could lay it, let alone smooth out the bubbles.
A lightened Prius could actually be fun to drive.
