Old 06-19-2019, 06:08 PM   #71 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by Nathan jones View Post
Incidentally while messing with my car I've found a few of these weights, exactly 1kg, huh
Theyre in places you wouldn't look
Where exactly were these? I'm curious if there are any on the Gen 3 I could remove; I haven't noticed any so far.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 06-20-2019, 05:35 PM   #72 (permalink)
Ecomodding Apprentice
Hi, two were underneath on the chassis and one was under the front bumper, I don't know if theres any behind the rear bumper
I wont get time to check this year...
The Following User Says Thank You to Nathan jones For This Useful Post:
TexasCotton (06-20-2019)
Old 06-20-2019, 05:39 PM   #73 (permalink)
Ive decided to do the bonnet as well. Not sure theres time in a week but am going to try a tidy and respray while I'm at it. It's may look hideous but rather than a homestyle chip foose kind of thing to just have line to break it up
And carmine red, a brighter red
Old 06-20-2019, 05:48 PM   #74 (permalink)
It should'nt flex once properly cured but making a light frame to support it
ID:	26246   Click image for larger version
ID:	26247   Click image for larger version
Old 06-20-2019, 09:33 PM   #75 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Questions
You are making a composite/fiberglass Hood/Bonnet? Yeah
I have consider doing this process However I am unsure of the know/how/DIY
There are obviously different weights/thread count/weave thickness to choose/use?
The resins seem tricky also to me as well?
How do you remove that cast (carefully for sure) without sticking to Hood/Bonnet?
Thanks in advance
Old 06-20-2019, 10:00 PM   #76 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
How much of the aluminum would you say you have replaced with carbon fiber?
Some sports cars have carbon fiber wheels...if the owner has an extra $25,000 to spare.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 06-22-2019, 04:41 PM   #77 (permalink)
Thanks, I'm still getting used to it, I've used four sheets of 200g so 1000g altogether
Depending on the strenth I will add more sheets/braces
Heres casting two small ones. Theyre glued on now
The Following 2 Users Say Thank You to Nathan jones For This Useful Post:
mpgmike (05-13-2022), TexasCotton (06-22-2019)
Old 06-22-2019, 04:45 PM   #78 (permalink)
I use cling film but you can use wax. There's three resins, polyester, vinylester and epoxy. I've used all three and don't think theres an awful difference. Epoxy is hardest and doesn't smell as much
I use 200g because it's easy to use and costs less. Woven glass is a very good substitute
I think the alloy bonnet is around 7kg at a guess. I don't have much more time but plan something with the doors, wings and hatch next year
Old 06-22-2019, 11:04 PM   #79 (permalink)
Thank you Nathan and I like your build and thread
Old 06-22-2019, 11:21 PM   #80 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Any fuel economy updates?
I believe I've said this before, but I personally have found any reasonable weight reductions to only improve acceleration, and that the fuel economy savings basically disappear into background noise.
