Old 06-20-2013, 03:25 PM   #21 (permalink)
Originally Posted by jamesqf View Post
Repair costs have been negligible: other than normal maintenance items, in 10 years I think I've replaced an O2 sensor and an EGR valve. I do take the battery out and rebalance it every year or two, but than doesn't cost anything but a bit of time.
Right now I feel like I only drive Bacon to the shop and back.
I have spent more on repairs than gas, as well as my "service plan." Between the plan that doesn't do anything and repairs, my car has cost 50% more.
Well, enjoy!
Old 06-20-2013, 04:45 PM   #22 (permalink)
90 day: 56.3 mpg (US)
(...) I have told people that Toyota copied the Insight, but I looked up when each was released in Japan and was confused, the Prius came out in Japan two years earlier, but you are right, the first Insight-shaped one was the 2,004 model. (...)
Like so many rules there are exceptions to it...
This is definitely a Prius shape
Old 06-20-2013, 06:41 PM   #23 (permalink)
IamIan's Avatar
So, which has a better hybrid system, the Toyota or the Honda?
The correct answer = It varies with conditions.
There is no one better option that beats the other in all conditions.
Also ... it would be more accurate to say the Gen1 Insight as a far less useful & far less efficient EV / battery only mode ... to say it has no EV ( battery only ) Ability , is technically incorrect.
Originally Posted by some_other_dave
Correction: Lean burn makes for higher emissions, in particular higher NOx. That's because the lean mixture burns hotter, which produces extra nitrogen-oxygen compounds in the exhaust.-soD
Negative.
Sorry to break it to you ... but some_other_dave is correct.
Even with an additional specially designed for NoX catalytic converter the Lean Burn enabled Gen1 Insight produces more NoX than the Non-Lean Burn Enables Gen1 Insight.
Lean Burn is more energy efficient ... but produces more smog producing compounds ( such as NoX ).
So, nobody clarified my misunderstanding:
Two catalysts sounds much better than two catalytic converters!
Insight owners, have some cake.
Eat it! Eat it and like it!
Actually it is 2 catalytic converts ... between them both there are two catalysts ... and there is also a 3rd piece involved ... the NoX catalytic converter also has a NoX storage mechanism to store surplus NoX until it can later ( outside of Lean Burn ) catalyze it.... but even with that ... it still will produce more smog emissions ( like NoX ).
Old 06-20-2013, 07:24 PM   #24 (permalink)
IamIan, I will ignore you, because you disagree with what I want to believe, but can we still be friends?
Old 06-20-2013, 07:38 PM   #25 (permalink)
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
A catalyst is a catalytic converter. However you are correct in that lean burn performs worse from an emissions standpoint. That's why Civic VX models from CA/CARB states don't have lean burn. They wouldn't meet their more stringent emissions standards.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
Old 06-21-2013, 02:12 PM   #26 (permalink)
Strictly speaking, a catalytic converter is a device, which could have any number of different catalysts in it.
That all depends on what importance you assign to different emissions. It's higher in NOx (which really matters only in densely-populated areas), but considerably lower in HC, CO, and - most importantly - CO2.
The Following User Says Thank You to jamesqf For This Useful Post:
IamIan (06-21-2013)
Old 06-21-2013, 02:17 PM   #27 (permalink)
Doesn't nitrous oxide induce happiness?
Old 06-21-2013, 09:00 PM   #28 (permalink)
IamIan's Avatar
I don't know you well enough yet to justify my use of the label "Friends" ... I don't hand out that label casually... only time will tell.
Old 06-22-2013, 03:07 AM   #29 (permalink)
Yes, after I posted I thought of a far less weird way of posting that, but hopefully was actually trying to study. Of course, I completely forget what it was.
For the record, "choosing to ignore you" was a joke, since that seems to be what many people do, but they certainly do not admit to it!
Old 07-03-2013, 02:20 PM   #30 (permalink)
AJI
Rallye - '98 Peugeot 106 Rallye
90 day: 31.93 mpg (US)
RX-7 - '94 Mazda RX-7
90 day: 20.76 mpg (US)
NC - '09 Mazda MX-5
90 day: 32.68 mpg (US)
Curious thread.
"Which is better?"... that rather depends on what you wish to do with them. A modern Prius will produce generally lower emissions, as it has a decade of extra refining and tweaking. Plus, it'll have a decade less wear and tear.
The Insight has massive potential, for those who can extract it. It's very light and quite aero-efficient, so doesn't need much effort to get moving and doesn't need a great deal of effort to maintain a cruising speed.
Subjectively, the Insight is also the more fun and looks much cooler. Objectively, the Prius is more practical.
Back in the late 90s, my ball would be in the Insight's court over which was better - on gas mileage alone, a gen-1 Insight makes a gen-1 Prius look a bit silly, even if you can't toddle around in EV mode like you can in the Prius.
Originally Posted by RedDevil View Post
I have to correct myself, the Prius C is not called Yaris over here but Yaris Hybrid, and I believe it does indeed have completely incomparably different taillights.
To clarify, the Prius C and Yaris Hybrid have the same powertrain, but they differ in far more than just tail lights. I suspect they're on a similar platform, but at the end of the day the Prius C is a Prius and the Yaris Hybrid is a Yaris - different exterior, interior, packaging, styling, name...
As a bit of a journo I went on the European launch of the Yaris Hybrid. Very nice little car. Apparently, Toyota chose to sell a small, Yaris-based Hybrid in Europe because the Yaris sells much better in Europe than the Prius does. In the U.S and Japan, the Prius name carries much more weight, so a downsized Prius is the more logical option (that said, the C is called the Aqua in Japan).
Their decision appears to be vindicated, at least in Europe, as I recall reading that Yaris Hybrid sales make up around 40% of all Yaris sales. Not bad going.
