Old 08-11-2012, 10:59 PM   #41 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Bigger struts are a good idea, just remember that on windy days the tail will act like a sail. you do not want to tip the car over.
A 2x4 or a 2x2 chuck might work well for an added safety support for when its open, you do not want anything crushed.
Old 08-11-2012, 11:01 PM   #42 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Do you think I could find struts good enough to support the tail when wind is hitting it? I wouldn't want to spend the money only to have a hatch that still needs supported by something.
The hatch itself is pretty easy to lift up because the extra length gives you a mechanical advantage. It does seem pretty heavy though as you make your way closer to the rear bumper.
Old 08-12-2012, 12:11 AM   #43 (permalink)
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
i dont know if this is a universal term but would "whalers" work?. basically two flat pieces arranged in an L cofiguration along the length. then you get rigidity in both directions.
does my sig work now?
Old 08-12-2012, 07:33 AM   #44 (permalink)
Wiki Mod
Will the struts work? no idea. its a try and see idea
Old 08-12-2012, 07:34 AM   #45 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
Nice work so far, can't wait to see it completed. I want to do something similar to my Escape, but I would like to make it easy to remove when needed.
Camry Thread
E-Bike Thread
Old 08-12-2012, 08:56 AM   #46 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Originally Posted by Weather Spotter View Post
Coroplast does not stiffen things up much. its good in one direction but the other it can fold in half with minimal effort.
A monocoque made with aluminum bar/aluminum sheet is MUCH stiffer than a monocoque made with aluminum bar/Coroplast sheet and won't need as extensive of an aluminum bar skeleton to be strong.
aerocivic.com
Old 08-12-2012, 10:14 PM   #47 (permalink)
Winsight - '06 Honda Insight
Gen-1 Insights
90 day: 72.19 mpg (US)
Looks like great progress!
Old 08-12-2012, 11:11 PM   #48 (permalink)
HydroJim's Avatar
I didn't get much done today because my family was over most of the day for my sister's party. I did have some time to work on the wiring inside the hatch although I haven't taken any pictures of it. The wiring is kinda of sloppy because I was using some scrap wire to save money but it's all about function in the ecomodding world. I'll be wiring the lights onto the car's light harness tomorrow so once I get done with that I'll start working on mounting the window.
Any tips for the window? material is my main concern. I have some plexiglass laying around but I know it scratches easy and I'm not even sure that it would be legal.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 08-13-2012, 11:05 AM   #49 (permalink)
basjoos's Avatar
I used 1/8" Lexan for my rear "glass".
aerocivic.com
Old 08-13-2012, 05:27 PM   #50 (permalink)
HydroJim's Avatar
Based on the strength of the 1/8" lexan, do you think I could get away with a thinner sheet such as 1/16" or 3/32"?
