Old 11-14-2009, 03:24 PM   #61 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
I think I'm going to aim for a 6 degree bottom angle, approximately what's shown there (don't do the photoshop measurement to check my work on this image - it's 5 degrees there.)
Bicycle Bob advocates for no more than a 4 degree angle. Unfortunately, that will leave the end of the tail a bit lower than I'd like for departing slope angles from the back tire.
Hi Metro,
When I read your post, the first thing that came to mind was to use Vortex generators to supplant the 6 degree angle. Then I read Bicycle Bob's comments and it seemed like a confirmation.
Jim.
Old 11-14-2009, 08:49 PM   #62 (permalink)
90 day: 51.82 mpg (US)
Didn't do a whole lot today other than set up the strings & rear "transom" you see below. Obviously if I follow the strings, I'm not aiming for curvature (going fore/aft) on the cardboard prototype.
Next step will be to cut out two more intermediate cardboard "bulkheads" that will help support the outer skin and the overall structure. There will be some triangulation in the aluminum frame too. Basically I'm winging it.
Should have more time to work on this tomorrow.
ID:	4758   Click image for larger version
Sorrow Six Star (11-15-2009)
Old 11-15-2009, 01:01 AM   #63 (permalink)
Wanderer
Sorrow Six Star's Avatar
Winona - '86 Subaru XT DL
awesomeness embodied! looks very cool!
Old 11-15-2009, 07:49 PM   #64 (permalink)
Hopefully the shape/angles are OK. Because it's no small task. Tuft testing will reveal all...
Tomorrow I need to make 1 more bulkhead, then find some thinner cardboard to skin it. The stuff I've used so far is double ply. Good for structural bits, but heavy and harder to cut/form.
Oh, and I should probably pick up another roll of duct tape.
ID:	4760   Click image for larger version
Old 11-15-2009, 09:00 PM   #65 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Can't wait to see how it goes! Encouragement encouragement encouragement!
Old 11-15-2009, 09:08 PM   #66 (permalink)
Originally Posted by Bicycle Bob View Post
Wheels are the 1st thing that come to mind, but they create point loads I try to stay away from.
Good point, that.
Old 11-15-2009, 10:13 PM   #67 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Darin,
You are a string artist! Looks cool just the way it is. Makes me think a tent designer could do something with fiberglass poles and ripstop nylon.
If and when I get around to my collapsable boat tail, I will make it four framed coroplast flaps that fold flat against the back of the van. Hinged on the trailing edges and joined with quick connectors. Unfortunately that pretty much makes it a square edged design to keep it simple and the dimensions would be restricted by the area available for the folded flaps when stowed.
Exciting work.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 11-16-2009, 12:05 PM   #68 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
Hmmm collapsing this SHOULD be very easy. use FABRIC to skin it and then have those aluminum polles in 3 sections that Telescope into each other with locking pins (or pop buttons like on EZ up tents if you can manage the fabrication or find the poles.
you could collapse the poles into each other FOLD them into the center and now you have something nice soft and FLAT to stow in the car.
the trick would be the frame ON the car. the easiest but most finicky would be welded SPIKES a few inches long that the tubes would insert ONTO to hold them at the right angle and stiff. then a couple bungies on the INSIDE of the tail to hold it all taunt.
Looking VERY nice so far.
Old 11-16-2009, 01:43 PM   #69 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
OMG, why didn't I see this thread before!!!!! Subscribed... Look forward to the sweetness that we should soon behold!
American by right
Ecomodder by choice
Hypermiler by necessity
Old 11-16-2009, 07:57 PM   #70 (permalink)
No sweetness today - all I managed to do was pick up a large box made of lighter cardboard that will mean making the skin will be easier.
Tomorrow I should have more time to fiddle with it...
boat tail, testing
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
