Old 12-24-2014, 05:13 PM   #181 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I'm curious how much mpg that Kamback is going to give you. Please do keep us updated!!!
Old 12-24-2014, 07:48 PM   #182 (permalink)
90 day: 51.82 mpg (US)
I'm honestly not expecting much at all. The Civic's rear glass/deck design is not bad to begin with.
But I will do an A-B-A test to find out.
The real value of having the Kammback is that it will provide the proper shape to transition to a boat tail.
I've gotta do something to try to wrest back the lost MPG from winter's icy claws!
aerohead (12-31-2014)
Old 12-25-2014, 01:03 AM   #183 (permalink)
Furry Furfag
I really want a boat-tail for my insight. I wish I could have gotten the one you made, but oh well.
Old 12-27-2014, 05:12 PM   #184 (permalink)
Well, if you plan ahead, you can have dibs on the Kammback and tail for an 8th gen Civic in about 6 months.
Old 12-27-2014, 05:21 PM   #185 (permalink)
Intermission: tuft testing
Continuing my habit of doing things all bass ackwards, may I present a photo from a quick tuft test of the Civic's rear glass this afternoon (now that I'm nearly finished the Kammback):
Above: you know you're a chronic ecomodder when your neighbour pulls in the driveway just as you're finishing taping the above on your window and guesses: "going to make something for the back end?"
Here are the tufts in action...
You know how in movies when there are a couple of people gathered around a video monitor showing something fuzzy and the boss says, "can you enhance that?"
I should have used dark tufts on the bottom 2 rows, because they disappeared into the light colour of the roadway. You'll have to take my word that the Enhanced Tufts (TM) are an accurate representation of reality.
I was slightly surprised to see separation/recirculation. The rear glass is laid way back and the deck is high. But, fail! It's obviously stil too "fast" to keep attached flow.
Also, I started on the mount for the tail's frame this afternoon.
ID:	16691   Click image for larger version
The Following 6 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (12-31-2014), Cd (12-27-2014), COcyclist (03-12-2015), Insight for life (12-27-2014), mikeyjd (01-15-2015), ScottDR (04-12-2015)
Old 12-27-2014, 05:26 PM   #186 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Oh that's great ! Laughing out loud.
I was glad to see the bit from Blade Runner in there too.
Old 12-28-2014, 11:27 AM   #187 (permalink)
boat tail frame
Stick tail frame under construction:
The height at the tip of the tail is right where the upper surface will arrive. Still have to work out width & bottom.
It adds 43 inches to the car's original 175 inch length, for a total of:
>>> 218 in. / 5537 mm --- Civic with tail
This will still fit in regular parking spots/garages. Longer than the best-selling car in the U.S. (Toyota Camry -- 4,805 mm 189 in.), but shorter than the shortest version of the most popular configuration of North America's best selling vehicle:
>>> 231.9 in. / 5890 mm --- 2014 Ford F-150 SuperCrew short box
Triangulation makes everything better:
It sits on the trailer hitch, and is secured to the trunk with bolts & wingnuts using the existing licence plate bolt holes. So far, it's relatively easily removable. I'll be adding straps across the top of the deck lid for redundancy.
ID:	16696   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (12-31-2014), mikeyjd (01-15-2015)
Old 12-30-2014, 12:40 PM   #188 (permalink)
This one's different from others I've made: it has a rear window and off-center-mounted third brake light, up high.
I just have to put the plastic skin on it, tape it on, and connect the light wires to the trailer harness.
ID:	16708   Click image for larger version
ID:	16709   Click image for larger version
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (12-31-2014), dirtydave (12-30-2014), Gasoline Fumes (12-30-2014)
Old 12-30-2014, 12:51 PM   #189 (permalink)
Looks like Darin is getting fancy on us!
Seriously, it looks good though. I can't wait to see the results.
Old 12-30-2014, 12:57 PM   #190 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Looks perfect! I am so going to copy your design! Good job!
What did you use for the back window?
What plastic skin will you use?
