Old 01-08-2008, 05:17 PM   #1 (permalink)
90 day: 51.82 mpg (US)
The question of how long to leave an engine idling at a stop vs. restarting it - and which uses more fuel - came up in this thread:
Pulse and Glide questions..Totally new to this
But I figure it's worth its own thread.
IWillTry wanted to know the same answer, so he systematically measured fuel consumption @ idle, and compared it to the fuel consumed performing a warm restart.
His observations (based on a 1.0L gas engine with throttle-body injection):
If you begin to extract useful work from your engine within 1 second of starting it, then the additional fuel consumed by restarting your engine is equivalent to about 0.2 seconds of idling. So you don't even need to consider how long you might be stopping for. If you're interested in reducing fuel consumption, turn your engine off whenever you can, and don't turn it back on till just before you need it. If you're a typical city commuter this can increase your mileage by around 10%.
He makes the same caveats about starter wear.
See his full report on iwilltry.org.
Old 01-08-2008, 10:33 PM   #2 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
On Jeeps website (I can't remember if it was the official one or a forum) they said that if you know your gonna be stopped for over a minute, you should turn off the engine, because you'll be using more fuel than idling it. That was with typical Jeep engines, which are normally atleast 2.5 liters for the 4 bangers in the wranglers. but on average a 3.8L or bigger.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 01-09-2008, 04:09 AM   #3 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
There's way more starter wear from excessive cranking/undervolting than from normal starts. IIRC the number of starts most starters can do before replacement/rebuilding is in the hundreds of thousands.
Old 08-14-2009, 04:59 AM   #4 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
from what i've got off my friends in the engine dept of certain auto makers it works out that depending engine age, wear, temoperature, proximity to service, cranking time it can soak up 12sec of fuel at idle in worse case on a 4 banger to restart providing it catches in the first few turns. most modern cars a i think safe margin is 4s@idle. so 4 sec after you've switched off at the lights, a smug grin can start spreading across your face! (as long as the lights are still red!!!! )
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 08-14-2009, 04:23 PM   #5 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I don't have to worry about this because I'm not running an alt, but the AH used for starting should be accounted for because your alt has to replace that energy into the battery using fuel. Anyone have starter amps/warm engine info?
One of the benefits from running at 18V is the almost instant start when the engine is warm.
Added: I see this is taken into account in his wikki. I think the higher idle speed after restart is probably because of the load of the alternator recharging the battery.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 08-14-2009, 07:29 PM   #6 (permalink)
JacobAziza's Avatar
Big Orange Work Truck - '83 Ford F-250
90 day: 27.54 mpg (US)
Jessica's - '04 Toyota Matrix
90 day: 41.21 mpg (US)
Ninjette - '01 Kawasaki Ninja EX250R
How and why do you run 18v w/o an alternator?
I removed my alternator, but haven't found any drawbacks to running 12v instead of 14.
Originally Posted by Piwoslaw View Post
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
Old 08-14-2009, 11:07 PM   #7 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I dunno about 18V, but you're probably not seeing a difference because you're not using even close to the load that a "normal" vehicle sees.
The ECU that you don't have, in some cases a TCU, BCM (Chryslers), high-tension ignition system, etc. all have to work on that measly 12VDC, so there is an advantage to overvolting to 14VDC, in that there is less voltage sag should everything decide to harmonize the battery draw at the same time.
If you've ever driven a gasser with a bad alternator, you know that it starts running like a wet dog right about the same time your headlights get dim. If you turn off the headlights, you get power back, once you turn them back on, you lose all power again. I drove my 1994 Hyundai Excel GL with no alternator for about 2 months back and forth to work... took 2 batteries each way.
Old 08-15-2009, 12:41 AM   #8 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
I'm running 18 volts because it's the simplest way to keep my voltage up. I have a 6V and a 12V in series.
12V (11.5 under load) is too low to keep voltage to the coil and fuel pump high enough for my car. Keeping 18V seems to add a bit to my MPG. I have not done any good "scientific-ish" testing so take my numbers with this in mind.
See this thread:
http://ecomodder.com/forum/showthrea...e-up-7551.html
Old 08-15-2009, 12:59 AM   #9 (permalink)
See this thread:
Do you have a stepper or something to make sure that you're not putting too much voltage to your ECU and related components?
Old 08-15-2009, 02:31 PM   #10 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Sorry about the hyjack...
I don't have any stepdowns. I will, at some point, tap just the coil, fuel pump and starter for 18V and tap the rest of the car at 12V. My only casualties have been my dome lights which I will swap for LEDs when I get a chance.
Cars are designed to able to take much higher voltage in case of alternator/regulator over voltage. Having said that, running at the higher voltage over time has overheated those dome lights. Do the tapped setup if you try this so you don't possibly let the smoke out of your ECU. Laziness can be expensive.
Idle less and save the world! (to keep on topic)
How do you get your car to warm up quickly? SVOboy EcoModding Central 65 01-08-2012 10:09 AM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
