Old 12-07-2012, 03:33 PM   #11 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
Compare tire size as well
2000 Insight MT 106K Citrus A/C
Old 12-10-2012, 12:19 PM   #12 (permalink)
Originally Posted by arcosine View Post
Tell us the rpm vs mph in each gear, 1 through five, compare speedometer with gps unit and idle rpm of each car.
Ok, I was able to get the following information.
The car idles around 600-700 rpm
Tires are 165/70/13's
Here are the rpms/approximate speedo mph (not gps verified yet)
1st gear: 2,000 rpm = 18 mph
2nd gear: 2,000 rpm = 31 mph
3rd gear: 2,000 rpm = 52 mph
4th gear: 2,000 rpm = 68 mph
5th gear: 2,000 rpm = 80 mph
Old 12-10-2012, 07:40 PM   #13 (permalink)
Rusty crusty trusty - '94 Honda Civic Cx
90 day: 36.13 mpg (US)
Vx - '92 Honda Civic Vx
90 day: 49.97 mpg (US)
Swap you instrument clusters they are easy to do possibly the spedo is off on one more than the other unless all this has been gps verified. The only taller gears are the hf final drive and the that is a cable trans not a hydro. The final drive can be installed but that's probably not the case. Most likely speedos off. I'm at 75 80 at about 2100 in the vx. Not sure with the cx no tach. Also are all tires and wheels the exact same size?
Old 12-11-2012, 02:07 PM   #14 (permalink)
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
2,000 RPM in 5th gear and going 80 MPH seems WAY off.
Below are 5th gear tests with the HX and VX trans in the EK generation civic. These are all in sync with a GPS.
80 mph = HX 3072 rpm/ VX 2680 rpm
75 mph = HX 2883 rpm/ VX 2520 rpm
70 mph = HX 2692 rpm/ VX 2350 rpm
65 mph = HX 2500 rpm/ VX 2180 rpm
60 mph = HX 2300 rpm/ VX 2000 rpm
55 mph = HX 2300 rpm/ VX 1830 rpm
50 mph = HX 2300 rpm/ VX 1640 rpm
