05-26-2012, 11:18 AM
master modder
radio mod
I ran the engine turn on wire to a switch and then to the radio so i can keep the radio off most of the time and i can only turn it on when the truck is on
and now im trying to make all my lights l.e.d like my cab light is now as well as my floor lights and my marker lights are now XD
-its hard to have a fun life if you don't have fun in life-
05-26-2012, 12:41 PM
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
I am a little lost...why not simply turn the radio on when the truck is on (or whenever you want) by using the power on/off button on the radio instead of hard wiring it?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
05-26-2012, 12:46 PM
The Dirty330 Modder
my radio is always turned on when the ignition is turned on. Whether the music is playing or not. he wants it to turn the power completely off from the radio when not in use.
that is what i believe he is saying, and i like the idea
"The only real mistake is the one from which we learn nothing."
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
05-26-2012, 12:54 PM
master modder
because it does not fully turn off the clock stays on and at night it sucks its so bright
05-30-2012, 11:56 AM
Function over form!
If it's a brightness issue, try a small bit of electrical tape - cover the clock. BOOM! instant free dimmer.
Sorry, not trying to be an @ss, just saying, if you want to reduce electrical load to reduce drag via the alternator, cool - but the radio (depending on your setup) is pretty minimal. Still, I'm always in favor of modifying stuff. Did you run a switch, so you can turn it on while parked if the "need" ever arises? If you have a wire, you're one more wire, and a toggle away from switchy goodness.
06-05-2012, 12:07 PM
master modder
it can only be on if the switch is on and the key is turned on and ya i am reducing the electrical load. im working on making all my lights led this makes a big difference the turn lights the break lights marker lights and running lights is 8 amps on my nissan and the head lights is another 8 amps i want to add a electric fan that is 10 amps so in the end it will only be useing 2 amps more then it is now
06-05-2012, 12:38 PM
http://ecomodder.com/forum/91157-post2.html
Work From Home mod has saved more fuel than everything else put together.
06-05-2012, 12:43 PM
Drive less save more
The dimmer switch that controls dashboard lighting usually controls the radio lighting as well. At least in my cars. I would want the radio off off as well when my car is parked, stupid design or the guy who installed it, did it.
The radio light should not come on until the headlights are turned on..
Save gas
06-05-2012, 01:45 PM
#9 (permalink)
Function over form!
Awesome - rather than improve one thing by 100%, improve 100 things by 1%. I like that. I agree with the complete LED overhaul, that should create quite a reduction in draw. Is the attempt to reduce draw to reduce drag via the alternator, or just to keep the additional draw with the e-fans minimized?
I'm curious what sort of increase in drag (% wise) this would create on the alternator, and what the outcome of that reduction would be in real world mpg.
I'd love to see the light overhaul when it's completed, along with some numbers!
06-05-2012, 11:21 PM
#10 (permalink)
master modder
to keep the additional draw minimized with my e fan
about mpg im not sure but by removing belt to the alternator is 10% increase and if you run a cut of switch to the alt is 5 to 6% increase and my electric fan should be 1 to 1.5 better mpg
and today i was working on the led tag light im almost done with it and about to buy some led blubs for the turn lights
