Old 08-04-2019, 07:17 PM   #351 (permalink)
Old 08-09-2019, 01:33 PM   #352 (permalink)
What is that? It's obvious what this is:
http://justacarguy.blogspot.com/2013...ay-garage.html
Old 08-12-2019, 09:05 PM   #353 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Probably the fins pump cooling air though the brakes.
- Tony
Old 08-13-2019, 11:30 PM   #354 (permalink)
Originally Posted by Snax View Post
Just a little micro-management going on at the rear of open wheel cars these days.
I'm assuming this is taken from behind the rear wheel, so those fins are leading air up and away from the wheel.
Looks like a lot of work cleaning up the wake, probably using the vortices formed at the tips of all those fins to specifically shape it for one thing or another.
Apparently skin friction and interference drag are over-rated?
The regulations are so strict about the bodywork that teams in open wheel series have resorted to exploiting loopholes in areas not covered by regulations. So, no, you're not going to see a smooth sidepod with trim winglets on top of it like Michael Schumacher had back in the day (the tricky little winglets that flexed juuuuust enough to reduce drag in the straights, then popped back up to give extra downforce in the corners)... instead, you get smooth areas where rules prevent adding wings and unregulated areas, like the bargeboard shown here, that sprouts wings and fences and vortex generators like barnacles.
Sort of like what happens when you tell fighters they can't have spiked knuckles in a fight, so they put spikes between the knuckles, instead.
Even the mirrors need to have an effect, as there's so little else you can do. Ferrari, in particular, ran into some trouble by putting a wing on a miror and calling it a mount...
The Following 2 Users Say Thank You to niky For This Useful Post:
RedDevil (08-14-2019), Snax (08-14-2019)
Old 08-14-2019, 04:28 AM   #355 (permalink)
just joined..
Civic - '15 Honda Civic Tourer SR
Came across these whilst googling for aero parts for civics..
https://www.all4honda.com/en/maxton-...pe-r-turbo-fk2
Possible benefit? Or just bling / showing off?
Old 08-22-2019, 02:07 AM   #356 (permalink)
Can bleeding edge racing tech be an oddity? Compared to this?
https://www.thesamba.com/vw/forum/po...uote&p=9144479
Luigi Colani, Jr.?
Old 08-25-2019, 09:36 AM   #357 (permalink)
What is that based on?
If it's flush with the rear tire, probably cleans up the wake. Possibly just bling. But it'd be interesting to test.
The Following User Says Thank You to niky For This Useful Post:
rob.e (10-01-2019)
Old 08-26-2019, 11:04 PM   #358 (permalink)
Doesn't look so bad at all
Old 08-26-2019, 11:07 PM   #359 (permalink)
Actually, it does.
Bicycle Bob (08-27-2019)
Old 08-26-2019, 11:25 PM   #360 (permalink)
Actually, it does.
I have seen worst things, just wasn't always able to take a picture...
