Old 05-13-2010, 12:59 PM   #1 (permalink)
30.67 MPG
carbonaltima's Avatar
Removable lexan grill block
I have some lexan lying around and was wondering if anyone has made a grill block. i would it to be removable also. Has anyone done this. Any tips. I drive a 2000 altima i don't know if that helps but maybe someone has some mounting techniques that i can use. thanks.
Old 05-13-2010, 01:29 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
it should be fairly easy to plug up the big holes in the front of your car with lexan. Just hold the clear lexan over the hole, and trace out the hole with a marker. Then cut out your plugs with a jigsaw.
I would probably paint the backside black so it is shiny black on front, rather than let it get grimey looking, if you worry about that sort of thing.
Also several dabs of hotglue or silicone can be pretty easy to remove/clean up. Or a couple small holes in the lexan and some black zip ties/bits of wire will probably suffice.
Old 05-13-2010, 01:49 PM   #3 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I like the idea. I used plexi instead of lexan.
http://ecomodder.com/forum/showthrea...sian-7329.html
Aero mods - new grill block and wheel covers - CleanMPG Forums
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Tacoma Grill Block mjboks Aerodynamics 6 01-11-2010 09:44 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
