Old 01-02-2010, 12:07 PM   #11 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
^^^for big gaps
^^^for the little gaps
90 Ft. Mortite Rope Caulk
Model # B2
Store SKU # 382841
$5.17/EA-Each
Mortite is the original name in do-it-yourself caulking; and it's still famous for quality & versatility. Mortite Weatherstrip and Caulking Cord will seal windows effectively. But it's also widely used as a gasketing material, sound deadener, insect barrier, crack filler and all around plugger-upper.
* Rope Caulk
* Special Project
* Use to fill cracks around windows or doors
* Fills up to 1/4" Gap
But I do recall seeing a specific temporary rope caulk that was for seasonal use. but this would do the same.
Old 01-02-2010, 01:15 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
WD40 -
Originally Posted by WD40 View Post
yes it does just peel off .. I used the same stuff many times over the years till I got double windows installed
Ok. Good to know!
CarloSW2
American Solar Energy Society
Old 01-02-2010, 06:28 PM   #13 (permalink)
this is the stuff you want .. its ez to use and remove
BULLDOG SEAL, SIL DRAFT STOP TRANS 300ML
Draft Stopd
I wasn't able to find that brand but I got what I needed (amazing how that works when you ask for assistance )
ya its kinda important. I have 2 big patio doors that are 30 years old and in pretty bad shape. The whole living room/kitchen/dining room is always very drafty. I'd love to replace them, but its just not in the cards at the moment.
I'll report how well it works in a week.
also a good tip for others is they make faceplate gaskets for lightswitches/electrical outlets. I installed those all around last year and noticed a marked improvement in my gas bill (about 10 bucks a month, not too shabby!!!). I guess it depends on the build quality of your house but if you have areas that aren't great with wall insulation, it really can make a big difference.
Removable boat tail snydertalon Aerodynamics 7 09-29-2009 01:53 AM
Removable grille block? Any ideas? Sean T. Aerodynamics 26 08-19-2009 10:05 PM
Prius Removable Kammback ENERGYprof EcoModding Central 20 08-04-2009 06:52 PM
