Old 11-28-2012, 04:02 PM   #41 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I had gotten some adjustable camber ones off a prelude on ebay..
preloaded --- its on the rack and pinion housing -- has a big lock nut -- opposite the steering wheel input.
- Tony
Old 11-28-2012, 04:22 PM   #42 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Manual says:
Preload- A predetermined load placed on a bearing during assembly or by adjustment.
So, it tightens up a bearing in the steering system. I might try that after the tie rod end stuff.
Old 11-28-2012, 07:08 PM   #43 (permalink)
Sven7's Avatar
Set up a deal to buy some 14" Honda HX wheels from a local guy for 50 bucks. Apparently they're like 11lbs per wheel? Winter is gonna be fun!
Old 12-01-2012, 06:14 PM   #44 (permalink)
Sven7's Avatar
Springs came! Just a matter of getting a spring compressor and a helper.
Oh and the ECU is marked February 1992 so it's definitely pre-OBD.
Old 12-01-2012, 06:27 PM   #45 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Honda used "OBD0" even on many of their late 80's cars. You won't be able to plug a scangauge into it but there are still electronic controls and error codes.
Old 12-02-2012, 12:22 PM   #46 (permalink)
Sven7's Avatar
MPGuino, then?
Old 12-02-2012, 08:40 PM   #47 (permalink)
Sven7's Avatar
Front shock assys came out pretty easily. I broke a 14mm Craftsman socket.
Rears, I sheared off the bottom nut on each side. So I'll have to punch those bolts through somehow and get new ones. No broken tools there though.
Going to get a spring compressor and new bolts/nuts tomorrow, and trade in that socket.
Old 12-02-2012, 08:56 PM   #48 (permalink)
Hah, wow.
I'm using an MPGuino made be a forum member and I'm quite happy with it.
Old 12-03-2012, 12:32 AM   #49 (permalink)
MPGuino it will have to be. They seem like pretty good stuff. I built one, but didn't get it installed in the CRX before I sold it.
-soD
Old 12-03-2012, 08:29 AM   #50 (permalink)
Vader - '15 Dodge Grand Caravan
90 day: 23.13 mpg (US)
Cmax - '13 Ford Cmax SEL
90 day: 40.92 mpg (US)
So in other words your were playing the game bloody knuckles
