Old 10-03-2012, 04:09 AM   #11 (permalink)
I always top of until the fuel pools on the outside of the spout to be negate the slope.
The Following User Says Thank You to seeodywhy For This Useful Post:
aerohead (10-03-2012)
Old 10-03-2012, 06:48 PM   #12 (permalink)
over thinking
Originally Posted by 2000neon View Post
I suppose this would be tough to do, and probably a major pain, but it would probably be interesting to try if you have a gas pump that you consistently use. To try and do one fill up with the vehicle sitting level (both front to back and side to side), and if a certain level of consistency was found, you could use some 2 x 4 wood blocks under one side at a time, with increasing height. It would be tough to get exact data, but based on what you observed, a trend/ correlation would probably appear based on "tilt" (camber?) of the vehicle. Then you could even play with it angled front to back to see if there is some difference.
Or maybe I'm over thinking it.
Also, I'm impressed to see a guy from Texas that understands freeze-thaw It seems most people here in Canada don't get the idea! But they are always the ones who notice the same potholes every year...
I feel like I didn't think it enough! Crazy! I'll start 'checking' from here on out.
The fewer unknowns the better.
2000neon (10-03-2012)
Old 10-03-2012, 06:54 PM   #13 (permalink)
MPGuino
Phil - any desire to put a MPGuino in your Toyota to digitally measure fuel use?
Opens up more testing options when you can get reliable consumption results from much shorter runs.
Darin,absolutely!
I'm behind in all matters since before the trip,but am convinced that 'tank' mpg is for the birds now that all the gee-whiz gizmos have availed themselves,and do,very much want to be dragged into the 21st Century.
'Have Wire-Strippers,VOM, and Soldering Gun,Will Travel.'
Old 10-03-2012, 06:59 PM   #14 (permalink)
pools
I've done this for years but never realized that if the vehicle wasn't dead-level,that there was a risk that I wasn't actually filling it completely.
In 4,300 miles of testing it will tend to nullify the discrepancy,but if it can be avoided,I'll pursue that direction.
If I'm going to share numbers,I'd like all the accuracy I can stand.
Old 10-03-2012, 07:45 PM   #15 (permalink)
CRX HF - '91 Honda CRX HF
90 day: 68.45 mpg (US)
I always use the exact same pump, but I haven't had my CRX more than 200 miles from home either.
The Following User Says Thank You to IsaacMTSU For This Useful Post:
aerohead (10-06-2012)
