Old 03-14-2023, 05:34 PM   #41 (permalink)
So you could recharge your [hypothetical] electric car/truck/garden tractor off of natural gas?
Old 03-15-2023, 03:13 AM   #42 (permalink)
Just like Nissan recharged test-drive units of the Leaf off of Diesel here some years ago
Old 03-15-2023, 04:22 AM   #43 (permalink)
Can't get diesel piped right to your house.
Old 03-15-2023, 04:43 AM   #44 (permalink)
90 day: 29.78 mpg (US)
No, but you can get it delivered by tanker minus road taxes. Currently sitting on 500 gallons of $2 diesel.
You think they swab EV exhausts to see if you're running off-highway diesel electrons?
freebeard (03-15-2023)
Old 03-15-2023, 10:00 AM   #45 (permalink)
Dang: #2 fuel oil (pretty much diesel with red dye) is $8 @gallon next door delivered last week.
Um, wanna see them swab the exhaust pipe on my E ranger.
Old 03-15-2023, 07:20 PM   #46 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Reminds me of the people who run their house backup generator on red diesel or the even crazier folks who can strip the red out of the offroad diesel and then use it onroad lol
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
Piotrsko (03-16-2023)
Old 03-16-2023, 01:06 AM   #47 (permalink)
Odd enough, in December I saw a CNG tanker truck in Florianópolis. Meanwhile, a 9-fingered SOB from Brazil is willing to use Brazilian taxpayers' money to build a NG pipeline... in Argentina...
Old 03-16-2023, 09:45 AM   #48 (permalink)
Just wondering what the process for removing the red dye is. I used 110 lowlead blue avgas in 5% as an experiment. Getting sticked on the highway isn't worth the hassle for me for a couple of $ and I could get all the clear Jet A I want drained out of wing tanks for REALLY cheap
What's wrong with the backup genset running offroad red?
Old 03-16-2023, 11:36 AM   #49 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
4kw @ 120v =33.3333 amps then add some for inverter losses so under 50 amps. 4kw @12 volts =333.3333 amps power in. Like > 2 gauge fairly short battery connections and some serious battery storage like a volt battery pack. Bet it cooks itself at those loads
Hmm, but no mention over on the diysolar site of this. Must be chineseium
This is why I decided to go 48V for my Ambulance / RV conversion. Once you start pulling any real loads the current and wire sizes get crazy. Even running a small electric heater as a test through a 2000 watt inverter put a huge sage on my 12 V battery voltage in my old campervan. (2 x 6V / 200 amp golf car batteries in series) 12V is fine for running a small super efficient fridge and charging some portable electronics but not much beyond that.
I also didn't want the hassle of stringing together 8 12V batteries when I could buy much more compact 48V server rack batteries. It is also very hard to find a 12V charge controller that can handle 1800 watts of solar.
This isn't a surprise though. It is almost universally agreed that cars should have moved from 12V to 24V 40 years ago and should be 48V today.
Originally Posted by RoadRaceJosh View Post
My inverter/charger is a Cotec that was discontinued. The Victron MultiPlus looks to be a good choice. https://www.victronenergy.com/invert...48v-800va-3kva
I'm 95% sure I'll be bying a 48V Victron Multiplus. That 5% uncertainty is whether I want to upgrade to multifunction unit. They take less space, and make the wiring cleaner but also cost more and give a single point of failure.
Old 03-16-2023, 11:37 AM   #50 (permalink)
JSH
AKA - Jason
JSH's Avatar
Nothing at all.
