Old 04-28-2015, 10:06 AM   #11 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Good going so far, man.
I love SAABs. I learned in a 1970 96, four on the tree and a length of twine holding the glitchy freewheel handle out. It got 40mpg back in the day, damned good - pretty good even now.
Interested to see how it plays out. I know having the instant grin factor of the turbo is an attractive temptation, knowing there's what amounts to four extra cylinders just waiting a little deeper into the pedal travel. That's hard to resist.
Old 04-28-2015, 12:41 PM   #12 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Completely doable, especially in the summer- I could string several 500+ mile tanks together in my 05 Subaru Legacy GT wagon with a 16.7 gallon tank.
Both cars are turbo manuals and they have similar EPA ratings, but the Saab's most likely got better aero and front wheel drive. Not far over 30 mpg will get you 500 miles, and until the car started to give out towards 200k I was getting in the 30s all the time.
Transmission type Efficiency
Old 04-28-2015, 05:09 PM   #13 (permalink)
The PRC.
Your gauge will go down faster on the second half because the float will be at the top.
Good luck.
Old 05-07-2015, 11:38 PM   #14 (permalink)
"The Tank" - '95 Pontiac Grand Am SE
Team Pontiac
90 day: 33.85 mpg (US)
SAABotage - '08 Saab 9-3 Aero
Team Turbocharged!
90 day: 29.83 mpg (US)
Update! Welp I completed my goal the other day! Had to circle to Gas Station to get the last .2 miles but the results were pretty decent. Best tank thus far at 32.63MPG out of the ole Saab. Not too shabby. I think I may aim for a 34MPG tank next.
As for the fuel gauge that is true of most older vehicles. Most now have adjusted the gauge to better reflect an even depreciation of the fuel.
Old 05-08-2015, 04:32 PM   #15 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Great fuel mileage!
I had an idea as I pondered before going to sleep last night. You could add an oil cooler before and after the turbo. It would cool the oil before it got to the turbo, and before it went back to the engine. This should lower the turbo's internal temperatures a bit, but it would require additional plumbing.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 05-08-2015, 06:49 PM   #16 (permalink)
The PRC.
Better solution maybe is an electric oil pump which continues to circulate oil when the engine is off. If the car is still moving then the oil is cooled naturally anyway. Could also circulate oil if the engine is shut off with a hot turbo. Kind of like a turbo timer ?
Old 05-08-2015, 09:37 PM   #17 (permalink)
Team Pontiac
Team Turbocharged!
The turbo is water cooled and pressure lubricated by engine oil which also provides cooling, making it both water and oil cooled. The car must have some sensor that when I drive it hard and really get into the boost it will power the cooling fans after it is turned off, for about 5 minutes.
When I am going for economy though, the turbo is getting a minimal amount of action. Shifting at or bellow 2000 RPMs seems to be the sweet spot.
Side note. I am currently at an average of 34MPG for 100 miles that are on it so far. This warmer weather has helped a ton! :-)
Old 05-09-2015, 11:29 PM   #18 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Some cars, turbo or not, have this fan run on feature if the car is parked with the coolant over X degrees. The idea is to avoid heat soak, not to save a hot turbo being shut down. If coolant/oil are not circulating, it's not cooling your turbo or engine for that matter.
Old 05-30-2015, 11:18 AM   #19 (permalink)
Team Pontiac
Team Turbocharged!
Whoops!! I forgot to post my goal being met!! 500 miles and 15.32 gallons.
I hit my 500 mile tank with relative ease a few weeks ago. I have currently been averaging 32MPG over the last 3 tanks.
Not too shabby for what it is :-). Warm weather is here so I may attempt a new goal of a 34MPG tank..... but we shall see!
Old 05-30-2015, 11:38 AM   #20 (permalink)
Nicely done Nate.
