Old 02-25-2009, 10:08 PM   #1 (permalink)
OurInsight - '06 Honda Insight
Scangauge Measurements on Mirror Removal?
Has anyone done any actual SGII testing of the advantage of rear view mirrors removal? I'd like to give it a try. Testing wouldn't seem all that hard, so maybe someone has done it already.
Old 02-25-2009, 10:15 PM   #2 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
I'll be testing this spring, just got my mpguino installed.
I'm sure MetroMPG has done it. might try a search, or try his website.
Matt
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 02-25-2009, 11:21 PM   #3 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
I tested mine a while back:
Runs with Mirrors:
1: 35.8
2: 37.5
3: 37.7
4: 38.6
5: 37.2
6: 38.4
Runs Without Mirrors:
1: 38.0
2: 37.5
3: 37.6
4: 40.1
5: 40.1
6: 39.3
Runs with Average: 37.53
Runs Without Average: 38.75
Was done at 45 mph with scanguage, cruse set and cancelled with brake then resumed.
Id imagine a bigger difference at higher speeds.
Old 02-25-2009, 11:27 PM   #4 (permalink)
90 day: 57.73 mpg (US)
Reflections on side mirrors: testing drag vs. MPG - MetroMPG.com
I did an A-B-A at 55 mph, cruise control also.
Except in my case A = both mirrors on, B = passenger mirror off, driver's side folded back
1.27 mpg (US) - difference between A and B run avgs
= 2.3% - increase in fuel economy at this speed, for this car.
Old 02-26-2009, 12:46 PM   #5 (permalink)
Mirror Data
Thanks guys. That is exactly the kind of sound data I was seeking.
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 03:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 07:31 AM
Baseline measurements skyl4rk EcoModding Central 1 02-24-2009 08:34 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 04:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 02:09 PM
