Old 10-07-2010, 01:00 PM   #21 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Y'all are aware that this is an Irish car, yes? I don't know if that has any influence on the problem but it seems to me that it might.
EDIT: I think that is the problem. From the ScanGauge FAQ:
Will the ScanGauge II work on my vehicle that was purchased outside of the US and Canada?
The ScanGauge requires the vehicle to be either OBDII or EOBD compatible. In the US and Canada, cars and light trucks were required to be OBDII compatible starting in 1996. In Europe, EOBD was phased in between 2002 and 2004. Other parts of the world have required one of them starting in various years.
Many vehicles made and/or sold outside the US and Canada had one of the protocols before they were required in that country. This was to allow sales to other countries and because they knew they would eventually be required to meet the requirements and designed it in when they redesigned a particular model.
There is no comprehensive list of when particular vehicles began using OBDII or EOBD outside the US and Canada.
Old 10-07-2010, 03:35 PM   #22 (permalink)
Brian's Golf - '00 Volkswagen Golf
90 day: 38.01 mpg (US)
I saw that before I bought mine but I also saw this, Scanguage also have a European reseller for their product. www.scanguage.net. and this is what they say about compatibility.
Will the ScanGauge II work on my vehicle?
The Scangauge II will work on most cars and light trucks since model year 1996. There are also some 1994 and 1995 models which the ScanGauge II will work on (Ask us). There are some vehicles built after 1996 that the ScanGauge II will not work on or has some limitations in the gauges and trip information (Ask us).
My car is OBDII it would have to be with 16 pins and the connecter fits properly.
Old 10-07-2010, 03:38 PM   #23 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I ran my battery down last week and SCII wouldn't come on. I unplugged the cord from the back of the unit with the engine running, plugged it back in and it worked for me. Might be worth a try.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 10-07-2010, 03:44 PM   #24 (permalink)
I've heard of some people disconnecting the battery to reset the ECU, maybe the same thing happened to You COcyclist when the battery died? That's definitly one thing I have not tried as of yet.
Old 10-12-2010, 06:28 PM   #25 (permalink)
testing signature
Old 10-12-2010, 06:31 PM   #26 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
looks good to me
Old 10-12-2010, 06:36 PM   #27 (permalink)
Thanks
Newbie! VW Golf TDi kammback ideas? theoteacher DIY / How-to 2 06-15-2011 08:34 PM
Big bumper or small? (VW Golf Mk2) G2TDI Aerodynamics 74 03-28-2011 02:29 PM
VW Golf mods matthew EcoModding Central 6 09-30-2010 12:42 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
Biodiesel UK test VW Golf - MPG results pending sallen Fossil Fuel Free 5 02-20-2010 11:09 AM
