Old 07-07-2010, 12:30 AM   #51 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Yep, I have the same conundrum... my VX has (relatively nice) alloy wheels (they came stock, made by Enkei)... I have no desire to drill into them, and I also don't have the cool center caps like Carlos has. Also considered the steel wheels, but the alloys are so much lighter (~9lbs vs ~14lbs for same size steel).
I think I've figured out a solution in my case, but still testing...
Old 07-07-2010, 12:38 AM   #52 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
A fairly easy solution would be to replace your studs with longer ones, so you'd have some threads left over to bolt something to.
Another solution would be to use longer lug nuts, so there were some female threads you could stick a bolt into from outside the wheel cover.
There's also the option to clamp the wheel cover on, as opposed to bolting it. You could pretty easily make something from a carriage bolt and an extra piece of tin or coroplast with a wingnut on it. Granted, you'd have to check on it periodically, but not altogether expensive if it were to come loose.
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 07-07-2010, 02:15 AM   #53 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
depending on your rims you could use some type of U-bolts with spacers
Old 07-07-2010, 02:17 AM   #54 (permalink)
Or (just thought of it now) JB weld some T nuts on.
Old 07-07-2010, 03:21 AM   #55 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Dr. Jerryrigger -
Yup, I've thought of those too. All good ideas.
CarloSW2
American Solar Energy Society
Old 07-13-2010, 01:17 AM   #56 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
Ok, the plumbing washer you see below has been a PITA because the glue I use to hold it in place doesn't adhere :
It has been replaced by a modified furniture foot :
1 - The furniture foot
2 - Cut off the bottom and drill a hole in the top-center
3 - The faux plastic lug nut (this one is unmodified, no hole drilled in center)
4 - The furniture foot pressed onto the lug nut
I also sanded off the bottom of the furniture foot, the "donut-shaped" raised part. This made it pretty much match the height of the plumbing washer.
CarloSW2
Old 07-14-2010, 09:00 PM   #57 (permalink)
- - '10 Toyota Prius III w/Navi
Hi All,
This is a situation where redesign of the wheel is the easiest expedient. Toyota did this on the Prius wheels. They put a groove in the ID of the wheel. There is an expanding steel wire ring that the cap (called trim rings on a Prius) that pushes some a portion of the trim ring molding into the grooves. When I did my caps, all I had to do was cover the trim (polystyrene with steel wire ring) rings which just snap back into those grooves on the wheels. This simple, elegent design is very effective, and adds no cost to the wheel, just a different casting tool. Of course the trim-ring is extra money.
On an existing wheel, maybe a piece of plastic with a groove in it could be glued into the ID of the wheel, that something on the cap could snap into.
Old 11-07-2010, 11:29 PM   #58 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
I've been wanting to install some wheel covers on my car for some time. Only problem has been the 16" mag wheels. Well, I picked up a set of used winter tires and wheels this year from an old Dodge Caravan. They were rusty and I needed to do something with them anyway so I finally had my chance. They came with bolt on center caps which made it pretty simple. I cleaned up and painted the rims to stop further rusting and polished the center caps. Then, I cut some coroplast donuts to fit the rims and a set of aluminum donuts to cover the rims, glued them together and painted them silver. The center caps hold them in place and they don't affect wheel removal. I may not see much improvement in mileage though, since I don't usually do much highway driving in the winter, but, it should help a little. Here are some pics.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
The Following 3 Users Say Thank You to puddleglum For This Useful Post:
aerohead (03-08-2011), cfg83 (07-04-2011), justjohn (04-28-2011)
Old 11-07-2010, 11:53 PM   #59 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
puddleglum -
That deserves it own thread with a few more "under the cover" pix.
CarloSW2
Old 11-08-2010, 09:48 AM   #60 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by cfg83 View Post
puddleglum -
CarloSW2
dito
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Alloy wheels + Metallic Tape = Aero Racing Disk cfg83 Aerodynamics 20 06-09-2010 03:23 AM
How many of us here come from a racing backround? blownb310 The Lounge 19 08-22-2009 09:20 AM
"Drag" Racing... Christ Aerodynamics 25 06-22-2009 09:44 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
