Old 08-03-2008, 01:43 AM   #21 (permalink)
I'm a newbie to SGII also. I just installed mine in my 2000 Insight this week.
FIA GPH
IGN LOD
I already have instantaneous MPG, trip MPG, H2O temp and RPM on the instrument panel.
Wish I could figure out how to program the X gauge to show when I'm in lean burn, but I can usually tell just from the feel of the car and the instantaneous MPG readout.
I'm still in the process of calibrating the fuel flow and the odometer functions. At an average of 81 mpg, I don't get many opportunities to fill the tank for calibration purposes!
Old 08-07-2008, 01:31 PM   #22 (permalink)
Eph's 08 NAH - '08 Nissan Altima Hybrid tech package
90 day: 46.13 mpg (US)
Someone I know who uses the SG with a Civic indicated that he watches the IGN closely.
How does this gauge help?
Eph
Old 08-07-2008, 06:59 PM   #23 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
My SG is loaded this way;
LOD AVG
MPG MPH
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 08-07-2008, 07:07 PM   #24 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
cephraim
I don't know enough to make use of the ignition timing reading but I've been curious about it as well.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-07-2008, 07:51 PM   #25 (permalink)
rjacob's Avatar
2017 Honda Civic LX - '17 Honda Civic LX
90 day: 39.92 mpg (US)
How si the IGN display used? It sort seems to move relative to the LOD display.
GreenCarMPG.com
Old 08-19-2008, 01:19 PM   #26 (permalink)
Happy Hyper
Jake's 05 Malibu - '05 Chevy Malibu
90 day: 31.42 mpg (US)
Send a message via Yahoo to jakemacd
I just got my SGII last week and have been tickled at the amount and instantaneous availability of the data. The book that came with it is OK but it doesn't go into depth with regard to all of the different gauges that are available. I've enjoyed gleaning knowledge from this site but I'm wondering. Is there a website that anyone can refer me to that would contain a comprehensive explanation of the powers of the ScanGauge?
Old 08-19-2008, 03:39 PM   #27 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
If there is a single source, I haven't found it. Usually I find what I need from forums like these or over at CleanMPG with dedicated sub-boards for Scangauge discussions.
UPDATE:
Avg FE Current Trip
MPG
TPS
LOD
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 08-25-2008, 01:53 AM   #28 (permalink)
The ign display shows the total ignition timing currently used. When running at it's most efficient levels or at very high RPM the timing tends to be more advanced.
I've notice when my Insight 5 speed is in "lean burn" mode the timing is anywhere from 26-30 degrees BTC. If I pop out of lean burn, the timing retards. This makes sense as a leaner, more efficient mixture combusts more slowly and needs more advanced timing to thoroughly burn.
SGII Not quite right dremd Instrumentation 37 09-26-2008 12:33 PM
SGII Read out trikkonceptz Instrumentation 1 05-16-2008 05:25 PM
any way to get SGII to show which gear I'm in? blackjackel Instrumentation 15 05-15-2008 06:29 PM
SGII + ICE OFF = .003 cpm? Chris D. Instrumentation 6 05-09-2008 02:00 AM
just got my SGII (ScanGauge II) few questions for the collective.. Chris D. Instrumentation 27 04-22-2008 07:38 PM
