Old 02-16-2011, 10:29 AM   #1 (permalink)
Dart Lite - '76 Dodge Dart Dart Lite
90 day: 18.34 mpg (US)
Beater..with a Heater - '94 Isuzu Rodeo LS
90 day: 16.19 mpg (US)
SGII, what inputs does it use to compute MPG?
What information does the SGII use to extrapolate the instant MPG and average MPG numbers?
Current MPG driver:
1994 Isuzu Rodeo - Beater with a Heater...
Old 02-16-2011, 04:55 PM   #2 (permalink)
It uses the MAF (mass air flow sensor) in the intake and the VSS (for vehicle speed). By knowing how much air goes into the engine it can use a preset A/F ratio to figure out how much fuel is burnt.
Old 02-16-2011, 05:28 PM   #3 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
MAF (air flow) for some cars, MAP (air pressure) and rpm for others like mine.
It also needs the engine size.
It assumes 14.7:1 air-fuel ratio.
Old 02-17-2011, 02:30 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Backtobasics -
This is what I think is going on :
http://ecomodder.com/forum/187883-post20.html
CarloSW2
American Solar Energy Society
Old 02-21-2011, 11:00 AM   #5 (permalink)
My truck is speed density, so no MAF. How does it use MAP and RPM to give FE numbers?
Originally Posted by cfg83 View Post
Backtobasics -
CarloSW2
Regretably, that is too technical for me.
Current MPG driver:
Old 02-21-2011, 11:07 AM   #6 (permalink)
I may be beating a dead horse. SGII asks me for engine size, but this is a hiccup. The truck was 5.2, but I swapped in a 5.9 a while back. EVERYTHING on the truck is still 5.2 based, but the block itself. 5.2 injectors, PCM programming, everything.
I use the SGII for instanteous driving feedback, more than anything. I have just learned about the tank fill up options where I can TUNE it completely to the truck, but I struggle to input the 5.9 when the PCM and injectors don't know it is 5.9 engine.
Current MPG driver:
Old 02-21-2011, 02:54 PM   #7 (permalink)
Hypermiler
Wagons
Use the actual engine size.
Using engine size, rpm, and MAP, the SG can calculate how much oxygen is being pumped through the engine. (piston pumps per minute * cylinder displacement * air density)
Then, assuming it's fuel injected and uses closed-loop O2 sensor feedback, the fuel must be ~1/14.7 of the air volume for a clean burn.
Really, though, calibration doesn't have to be ideal. If you improve your driving technique by 10%, you'll see a 10% improvement at the pump.
Old 02-21-2011, 04:02 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Backtobasics -
It's too technical for me too. I've read versions of similar algorithms over and over. Everything I did is based on this post :
Calculating MPG from VSS and MAF from OBD2
What I programmed is a lot of trial and error until I saw MPG behavior in the same range as the SG.
CarloSW2
Old 02-21-2011, 04:14 PM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Backtobasics -
I think the SG is making a synthetic MAF :
Code:
IMAP = RPM * MAP / IAT
MAF = (IMAP/120)*(Volumetric_Efficiency/100)*(Engine_Displacement)*(MM)/(R)
Where :
- manifold absolute pressure (MAP) is in kPa
- intake air temp (IAT) is in degrees Kelvin
- R is 8.314 J/°K/mole (constant)
- The average molecular mass of air (MM) is 28.97 g/mole (constant)
Note that in the above formula, the Volumetric_Efficiency of the
  (4-cycle!) engine is measured in percent
Note that the Engine_Displacement is in liters.
In my opinion, there is an assumed Volumetric_Efficiency. When you do a fill-up and apply the correction factor, the correction factor modifies the Volumetric_Efficiency for your engine.
CarloSW2
Old 02-24-2011, 08:33 PM   #10 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
Hey, one doubt here:
If MGuino MEASURES the injector pulses and integrates them, whereas SGII just 'guesses' about the fuel being used, I would expect MPGuino to be more accurate. Is this conclusion correct?
Also, what is the strategy the in-built FE meters in the new generation cars use? SGII one, or straight computation of fuel a-la MPGuino from the ECU itself?
