03-04-2008, 07:52 AM
#21 (permalink)
Originally Posted by DifferentPointofView
huh... for some reason its not working
You have to create the image first by editing/updating one of your fill entries. It's not available until you do that.
Also, Andrew's method of getting the image will work too. The code snippet I posted also made the image a clickable link to your fuel log.
03-04-2008, 02:14 PM
#22 (permalink)
Eco Noob
Awsome Sig Line - Is this something that would work for any other forums? I would like to use this on the Altima Forums to help draw awareness to ECO driving.
On a side note - the 1st tank i added was my "Old Way" of driving - my 90 day average is a little low - but one more tank will kick the 1st one out.
Steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
 First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
03-04-2008, 02:24 PM
#23 (permalink)
Dartmouth 2010
You should be able to use it in other forums, right darin?
03-04-2008, 02:25 PM
#24 (permalink)
If you want to post your image in another forum, you can. (I think that's what you're asking.)
You could try just copy/pasting the same code you used in your sig here. Depending on the Altima forum software, it might be that simple.
If it's not, you 'll have to figure some way to incorporate your image url, which is:
http://ecomodder.com/forum/fe-graphs/sig108a.png
And use that particular forum's syntax to make it an active link back to your fuel log.
BTW - nice trend in your log.
03-04-2008, 02:50 PM
#25 (permalink)
Pokémoderator
MetroMPG -
I am most pleased with the results.
CarloSW2
03-04-2008, 03:24 PM
#26 (permalink)
It definitly looks good. However, I dislike filling out multiple gas logs. I put in my Paseo's info since there aren't a ton of tanks. The Matrix would have taken forever to transfer from cmpg...
Just a reminder to the guys that are using this, use URL tags so it links to your log!
03-05-2008, 12:05 AM
#27 (permalink)
Giant Moving Eco-Wall
AndrewJ's method would work.. if I could fill my tank!!! lol. Okay, so THAT's why it didn't work... I need to put in a new fuel log  stupid me.
03-05-2008, 12:46 AM
#28 (permalink)
UnderModded
Pablo - '07 Hyundai Santa Fe AWD 90 day: 23.62 mpg (US)
And just suppose someone read this thread has no idea how you are actually attaching these "signature images"... or even where to start.
*webtard*
03-05-2008, 12:51 AM
#29 (permalink)
Dartmouth 2010
Go into the user CP and to edit signature and just put the code bits talked about in img tags (you can also click the img button in the WYSIWYG editor and just paste in the url.
03-05-2008, 08:20 AM
#30 (permalink)
You don't have to make a new entry - if you just edit/update an existing entry, the image will appear at the bottom your fuel log page.
