Old 08-22-2010, 11:39 PM   This thread is in the EcoModder Project Library | #1 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Simple Honda VX Alloy Wheel Covers (drilled acorn wheel nuts as attachment points)
I'd posted this inside another thread, but realized the information probably deserves its own thread.
Got these done a few weeks ago, and they have worked out quite well.
Used a melamine serving tray from KMart (fairly light weight compared to pizza pans) ($4.99 ea):
Drilled out the acorn nuts and epoxied in some washers plus smaller nuts inside:
They're actually all centered... just looks off:
Epoxy is setting now... using bolts & nuts to hold the nuts inside straight:
Lug nuts ready to go back on the car:
And now back on the car:
Drilled 4 matching holes into the serving tray:
The design of the bottom of the tray made it exceptionally easy to mark 4 evenly spaced lines and the center point. Measuring 50mm (5cm) out from the center to get to the same spacing as the 4x100 lug nuts was a snap. All the holes have lined up with all the lug nuts perfectly twice so far (left and right covers).
Hot-glued washers and spacers to the wheel side of the tray so they don't keep falling off during the mounting (it ain't purty, but it works):
Initially, the tray was a little big and rested on the edge of the rim:
I didn't like that, so I sanded the edges of the tray down until it fit exactly inside the edge of the rim:
Final look is pretty decent; plan to also sand down the ridges so the whole 'bottom' / outside of the tray is smooth, and then will likely paint them. Also plan to smooth the edges of the washers so they don't present such a sharp edge:
For these covers, I prefer to remove the clip-on weights on the outside of the wheel and have the tire shop re-balance with the stick-ons (or clip-ons on the inside only) so that I don't need to cut notches into the covers just for the weights. Since it's a relatively quick 4 phillips screw on / off process, and since the tires are holding air really well, I'm not too worried about having an opening for the air valve.
Last edited by NachtRitter; 09-07-2010 at 02:56 AM.. Reason: Added some more detail to the steps
The Following 17 Users Say Thank You to NachtRitter For This Useful Post:
beluga (12-27-2013), bespurcell (11-20-2014), brucepick (06-07-2011), Cd (01-15-2011), divedaddy03 (07-19-2012), ECONORAM (12-25-2010), Impulse (08-07-2011), MetroMPG (08-23-2010), mikeyjd (05-29-2014), Mira (03-06-2013), OG VX (10-08-2014), Patrick (08-24-2010), pdq54 (04-21-2012), Piwoslaw (07-04-2011), poobah318 (03-31-2013), Sven7 (03-05-2013), SwamiSalami (01-15-2012)
Old 08-22-2010, 11:45 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I dont think those could fit any better!
so the screws go into the tops of the lug nuts?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-22-2010, 11:55 PM   #3 (permalink)
Very very nice.
Why not just drill and tap the lug nut holes?
regards
Mech
Old 08-23-2010, 12:10 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
NachtRitter -
Great work! I've seen a lot of 14" plates, but that was always too small for my 15" wheels.
CarloSW2
American Solar Energy Society
Old 08-23-2010, 12:34 AM   #5 (permalink)
NightKnight
Diesel
Right; with the spacers, the bolts / screws snug up against the lug nuts. Stays nice & snug, no wobble, no noise.
Old 08-23-2010, 12:47 AM   #6 (permalink)
NightKnight
Diesel
Originally Posted by Old Mechanic View Post
Very very nice.
regards
Mech
That was my original plan actually. However, once I drilled the hole into the top of the lug nut, I found out there really isn't much metal there to tap... Maybe a 32nd of an inch. That's when I came up with the idea of inserting a washer plus a nut and using epoxy to hold them in... I put anti-seize on the threads of the lug nut and on the bolt for the smaller nut, threaded the nut over the bolt so that it would stay true, "poured" the epoxy in, and then let it sit for ~12 hours. The bolts unthreaded fine, and no epoxy stuck to the lug nuts either.
I was worried the epoxy wouldn't hold strong enough, but I can actually tighten the bolts down pretty well.
Old 08-23-2010, 12:20 PM   #7 (permalink)
Mirage - '93 Mitsubishi Mirage ES
90 day: 41.92 mpg (US)
Good work!
I shall copy this.
Old 08-23-2010, 01:55 PM   #8 (permalink)
90 day: 51.82 mpg (US)
Good DIY! Thanks for posting.
Old 08-24-2010, 02:32 PM   #9 (permalink)
NightKnight
Diesel
Originally Posted by cfg83 View Post
NachtRitter -
CarloSW2
Carlos -
I have to thank you for the inspiration... Your serving tray thread (http://ecomodder.com/forum/showthrea...isk-11838.html) is what gave me the idea of attaching to the lug nuts... since I didn't have any nut caps handy, I improvised.
The Following User Says Thank You to NachtRitter For This Useful Post:
cfg83 (08-24-2010)
Old 08-25-2010, 01:20 PM   #10 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
NachtRitter .. excellent way to mount them on the VX rims .. I was looking at the idea many times but didn't want to drill into the rims. This solves the issues.
Are you going to do any A-B-A tests, or give educated guesses on mpg gains?
Again awesome solution.
2000 Insight MT 106K Citrus A/C
flat wheel covers, moon
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
