Old 10-28-2017, 06:12 PM   #1 (permalink)
simple spoiler to prevent cover from lifting
There is a skylight larger than the one I am posting that the wind while traveling shakes the cover and undoes the latches, causing it to open. Would a spoiler such as a strip of aluminum angle prevent lifting, like in the picture? I say its 3/4" but maybe much smaller (1/2") would work? Thanks for commenting.
WW
Old 10-30-2017, 12:49 PM   #2 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I had a pop-up camper roof vent that would crank itself open from the wind buffeting over it. I fixed it with a mini bungee on the crank handle inside before lowering the top for travel.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 11-01-2017, 06:36 PM   #3 (permalink)
I'm a little skeptical because it's in the wind shadow of the center peak. That may cut it's efficiency in half. Technically it's a Gurney flap or wickerbill, look those up; I forget what situation they are used for.
I see the rivets that show it has a center bar. I have four 14" square vents. What I use for closure is a full 36 inch piece of 1/8th inch welding rod curved in the center for 19 1/2 inches so it will slip over the center bar. The tails are bent at 90° to each other (aids in install/removal) and so they lay flat against the ceiling. I can't imagine them pulling through, but there is certainly opportunity to double up.
Old 11-13-2017, 01:30 PM   #4 (permalink)
ASV
weirdo
ASV's Avatar
the rattling is caused by turbulent air flow
if you add a ramp forward and behind the skylight smoothing out the airflow the rattling will go away
and as a bonus a tiny little bit better mpg
The Following User Says Thank You to ASV For This Useful Post:
freebeard (11-13-2017)
