Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-17-2008, 02:10 PM   #31 (permalink)
Hi Rich,
I dunno -- that doesn't sound right. Volts X Amps = Watts is what I was taught.
Old 09-17-2008, 03:36 PM   #32 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
[QUOTE=Xringer;61712]
Originally Posted by WisJim View Post
Here ya go!
Watt - Wikipedia, the free encyclopedia
The watt (symbol: W) is the SI derived unit of power, equal to one joule of energy per second. It measures a rate of energy use or production.
Wikipedia is correct, you just didn't read the rest of it.
to quote Wikipedia:
"Confusion of watts and watt-hours
Power and energy are frequently confused in the general media. Power is the rate at which energy is used (or generated). A watt is one joule of energy per second. For example, if a 100 watt light bulb is turned on for one hour, the energy used is 100 watt-hours or 0.1 kilowatt-hour, or 360,000 joules. This same quantity of energy would light a 40-watt bulb for 2.5 hours. A power station would be rated in watts, but its annual energy sales would be in watt-hours (or kilowatt-hours or megawatt-hours). A kilowatt-hour is the amount of energy equivalent to a steady power of 1 kilowatt running for 1 hour, or 3.6 megajoules."
And the definition of Joule:
joule (jūl, joul) pronunciation
n. (Abbr. J or j)
1. The International System unit of electrical, mechanical, and thermal energy.
2.
1. A unit of electrical energy equal to the work done when a current of one ampere is passed through a resistance of one ohm for one second.
2. A unit of energy equal to the work done when a force of one newton acts through a distance of one meter.
So if you read both of them it becomes very clear that a Watt is not a watt second, because then a watt hour would be a watt/second/hour, and that would be kind of like giving speed in miles per second per hour...
Old 09-17-2008, 04:44 PM   #33 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Time is on my side, yes it is...
Hi Rich,
That's right.
A volt is a potential. It's kinda like air pressure in a tire.
It's at 44 PSI, but it's not doing any work, it's just sitting there.
An Amp is not the same thing. It's the amount (count) of electrons that flow past a point(like an Amp Meter) in a circuit for one second.
Like water flowing in a hose.. The Amp meter is like the GPM meter on a fire engine. Only, it's coulombs per second.
If you have a 12V battery and 6 ohm soldering iron, that iron is going to draw 2 Amps off the battery. V/R=A or (I=E/R)
The iron will heat up and output 24 watts of heat, every single second. (current squared times the resistance in ohms).
If you only turned on the iron for 1/2 a second, it would dissipate 12 watts (as heat).
If you sat there flipping the switch off 1 sec and back on 1 sec repeatedly,
the average wattage(over time) used by the iron would be 12W.
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 09-17-2008, 05:04 PM   #34 (permalink)
[QUOTE=Ryland;61723]
to quote Wikipedia:
n. (Abbr. J or j)
2.
Does "a watt" mean 1 watt?? (Like if you say, "a pound", you mean 1.0 lbs.).?.
"The watt (symbol: W) is the SI derived unit of power, equal to one joule of energy per second. It measures a rate of energy use or production."
As in E x I=P..
I'm not sure that anyone here is confused about the KWH on their electric bills.
And I have no clue as to why someone added that extraneous info to the definition of the Watt.
Maybe I should go delete that part out.?.
Cheers,
Rich
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 09:19 PM
Solar cell panel on the roof..?. Xringer EcoModding Central 5 09-07-2008 01:51 AM
