Old 08-23-2008, 09:30 PM   #1 (permalink)
oldtech1's Avatar
solar pannel charging issue
im wanting to make a homebrew solar charger.a 6"x6" pannel x6
1 for each battery with plans for a quick break to separate contacts of each
battery.The issue is i need a way to auto disconect the solar pannels when
batteries reach full charge so as to not damage batteries by overcharging.
is there a cheap solution that i might can buy at the local radio shack
or other local stores.and will i need a diod on the + from the pannel to
keep battery bleed from hurting my pannels.
Old 08-24-2008, 02:54 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
oldtech1 -
I have a "marine style" flexible solar panel :
http://ecomodder.com/forum/49870-post25.html - Post #25
http://ecomodder.com/forum/50044-post35.html - Post #35
For $20, I got this to go between the panel and car battery (via the cigarette lighter outlet) :
Sunforce Products 60012 7 amp Charge Controller : Hechinger
Because of the low amps of the solar panel I have been assured that it isn't needed for my solar panel :
http://ecomodder.com/forum/49137-post19.html - Post #19
CarloSW2,
In my experience, a charge controller is unnecessary for anything less than 100W while charging pB-A battery. You do loose power without a MMPT, but it is not necessary. The current is what charges the battery, and it will be delivered at whatever the battery voltage is instead of the nominal operating voltage. You could just put your panels in parallel and be done with it.
However, I have murdered many a battery in my day, and I like to see the "charging light", so I am happy with the setup.
CarloSW2
American Solar Energy Society
New Solar Panels trikkonceptz General Efficiency Discussion 10 08-27-2010 03:11 AM
Solar trickle chargers JJW EcoModding Central 15 12-03-2009 05:48 PM
Motor, battery and solar panels for a boat Wywern Fossil Fuel Free 11 02-17-2008 08:22 PM
DIY Solar charged electric scooter MetroMPG Fossil Fuel Free 4 01-09-2008 11:27 PM
Welcome to the Solar Century trebuchet03 The Lounge 4 01-06-2008 03:38 AM
