Old 12-14-2008, 04:16 PM   #11 (permalink)
sketch too big
Originally Posted by orange4boy View Post
Remember, this is an open source diy kit so you have to be prepared for some issues. MPGuino is still tons cheaper and more customizable than scanguage.
To relaod the code you have to download and run the arduino 011 program, cut and paste the code from the google code page into a new sketch, plug in your Guino with a usb and click on upload to I/O board. try that to see if it works. If you get a sketch too big message (i did on a mac) I could post my reduced sketch for you.
Good luck
Orange4boy:
I got the sketch too big message as well using arduino 0011 on Ubuntu. I would appreciate a pointer to your reduced sketch.
Thanks
Brownell
Old 12-14-2008, 04:37 PM   #12 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I will try to attach my shortened sketch here. Perhaps dcb can look it over and see if I've done anything that might compromise the sketch, or reduce the sketch himself so it remains functionally correct.
I will have to do it later because we are having a water emergency. (fixed!)
I will have to email it to you. I can't find a format to attach that is small enough and I only have stuffit expander. Unless someone can help me out with a hint.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
iDuino MPGuino wyatt OpenGauge / MPGuino FE computer 146 02-20-2009 12:23 PM
Help - Spiffie MPGuino Problem moorecomp OpenGauge / MPGuino FE computer 10 11-13-2008 02:09 PM
