Old 06-04-2010, 09:57 PM   #1 (permalink)
Starting MPGuino quest
Hello all!
I stumbled onto this forum after looking at a Scangauge and realizing it wouldn't work with my '95 Civic. I discovered the MPGuino project and it dovetails nicely with my penchant for DIY. About time my car was modified.
I have read many threads, poured over the wiki and google group, but still have a question that's made me very confused.
I get the impression that the latest version of MPGuino (0.86?) cannot be used with a stock arduino (point 3 under framework in this thread: http://ecomodder.com/forum/showthrea...tml#post171793). Am I reading this correctly? I have an Atmega328 here which I planned on using for this project. I could easily program it in an arduino, but if it doesn't work that way, I'd need to make a programmer.
Also, I'd like to put this together on protoboard and put it in a custom enclosure. There's nothing on the schematic (Picture) that should stop me is there?
Thanks in advance!
Old 06-05-2010, 04:54 PM   #2 (permalink)
Hi! I am also new to this forum and recently installed mine in car.
I have Arduino Duemilanove USB board with atmega328 chip and it works nice.
I used this shematic:
Old 04-27-2013, 10:48 PM   #3 (permalink)
stewie's Avatar
Milano Red VX - '92 Honda Civic VX
90 day: 50.15 mpg (US)
HI guys. I have 0.86 version and wiki is up to date only to .80. My question for Jamdat and anyone with Civic 92-95 what are you settings for all values. It seems wiki only provides 2 values but there is like 6-8 and one is weight and default was incorrect so are rest incorrect to. All those values have to be correct right?
What are the settings values for all settings not just two?
Also how you guys calibrate the mpguino? I have 175 tires not 165 so what would i adjust and to what value.
Old 04-30-2013, 05:05 AM   #4 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Weight is not in use. You can put anything there. It's like the scratchpad, aka. notepad.
usecGal/injdelay, these are all you have to concern regarding injector signal.
Except that Up/Down setting is for determining if the injector signal is gnd or +12V. Majority of vehicles is ground-controlled, meaning "Down". And that is already default.
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Super MPGuino? gtkid2002 OpenGauge / MPGuino FE computer 97 02-06-2011 12:39 PM
Speedo Accuracy with MPGuino :-( hummingbird Instrumentation 4 04-07-2010 12:26 AM
Scanguage vs MPGuino - 96 Prizm justjohn Instrumentation 16 02-18-2010 02:39 PM
Mpguino not fully starting, or locking up wagonman76 OpenGauge / MPGuino FE computer 15 08-27-2008 08:11 AM
