Old 07-22-2008, 06:20 PM   #41 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Originally Posted by dremd View Post
Any reason for the Muslin over gluing the tubes direct to the foam? (Probably are)
My guess is to keep the tubing down so that it stays in the channels, it may also wick away condensation.
What is Tygon Tubing?
Tygon is a modified polyvinyl plastic. Tygon tubing is most commonly found in laboratories and the food industry. It is very clear and so resistant to chemical attack, it will handle practically any chemical without damage, even from prolonged contact. Because of its flexability, it will curve around corners and is resistant quite durable. It's also pretty cheap, considering other tubing solutions. If you need to make the tubing more flexible, just dip it in boiling water for a few moments.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 07-22-2008, 07:12 PM   #42 (permalink)
Any reason for the Muslin over gluing the tubes direct to the foam? (Probably are)?
To keep the tubing where you want it, it also adds a thin layer that won't abrade the inside of the factory seat cover.
Brand name for a popular flexible clear PVC or nylon tubing perfect for your application. The silicon tube might stay flexable longer though, Tygon gets brittle after a few years, but it's cheap VWR and Cole-Parmer are great sources for tubing, connectors and maybe industrial and scientific grade pumps. McMaster-Carr, too.
edit: I posted before I read the above, about Tygon
Old 07-29-2008, 03:39 AM   #43 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
Encouragement for dremd
Dremd,
I hope everything is well
I received my cool-or-heat seat in the mail today & discovered it was assembled with velcro
so... you guess it - I immediately disassembled it
I have thus discovered some things that will aid you on your quest
first a picture (see below)
the whole seat uses one continuous tube
great for preventing leaks - and works reasonable well for the 2 square feet that are cooled by it
If you let the thing get up to speed the whole tube stays cold
so your design with 4 loops top and bottom will be potent indeed
next the loops only cover about 1 square foot on your back and one square foot under your butt
this is not enough area to really cool you off if you are really hot
- in your design you will want to cool as much of your seat that touches you as you can
but I believe in the case of this design - the area to be cooled is sort of matched to the cooler capacity.
finally the tubes are laid in a thin sheet of foam before being inserted in the seat cover
the foam appears to have a track melted/removed in it for the tube and the tube laid in it with a bit of adhesive
as an engineer I like the design and the peltier concept
but the product itself is not impressive - it is a Pinto not a Lexus
the major limitations are appearance/ruggedness of the cover and cooling capacity
but you will not have these issues with a leather seat and an ice bucket for a heat sink
There is lots of modding potential with this silly thing - but i will use it "as is" this summer
who knows, I may be modding my seat like you next summer
I might even Borg this thing into my truck
interested in your progress
Name:	small cool seat pic.jpg
Concrete
Start where you are - Use what you have - Do what you can.
Old 07-29-2008, 09:30 PM   #44 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Well I'm ok; crazy but Ok.
No internet until today
No Phone until today
And a wrecked car in the house.
Sorry No progress yet.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 07-29-2008, 11:51 PM   #45 (permalink)
Sequential
Concrete's Avatar
Say What!
Um... "a wrecked car in the house"
you don't have to apologize about progress with that going on
I hope everyone is safe
Hang in there
Concrete
Old 07-30-2008, 12:52 AM   #46 (permalink)
EV OR DIESEL
EveryBody is Physically OK That's the important thing.
Yes; a family member ran the 05 vibe up on something hard and yellow.
That Same family member pushed me over my Fair Access Policy for Wild Blue
The phone is probably (99%) my fault.
The vibe Err
Radiator support bent in 10"
Lower tie bar looks like a pretzel
Bent Tie rods
Smashed Grill
Smashed A/C + radiator
It's been killing 99% of my free time.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 07-30-2008, 04:34 AM   #47 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Honda Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ford Ranchero GT
Spaz - '83 Chevy S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
The vibe Err
Bent Tie rods
Smashed Grill
Sounds like a certain family member may get FAP'd too!
(Glad no one was hurt!)
Man if you don't hurry it'll be winter and I'll have to figure out how to hook a coffee maker to this thing to heat the seat so I won't have to run the heater fan! Um...new idea gotta go!
Honda...the economical, renewable resource.
Old 08-06-2008, 03:47 AM   #48 (permalink)
Sequential
Concrete's Avatar
Butt-0-Meter test of cool-or-heat seat cover
Dremd,
hope all is well
I'm sure everything is not full speed after the Evel Knievel Vibe event
butt.... I have some data from using this cool-or-heat seat for a week or more that might be of interest to you (and maybe MazdaMatt and the "cool towel")
putting aside the slow thermal electric issues and issues with my particular seat cover there are some basic problems with cold tubes and butt cooling I have discovered.
The seat cover I have has a very thin cover of nylon between me and the tubes so keep this in mind as I relay my issues
Condensation is a problem -
it might be less thru a thicker layer of leather - but I can see the wet outline of the cooling tube path after I have sat & sweat on it.
Cold tubes can be very uncomfortable to sit on -
perhaps for a cool shirt that lays on your skin this is acceptable
but when gravity presses your arse & back into a cold tube that is wet with sweat - it is almost painful
I have had to turn this wimpy thermo-electric cooler off because it was uncomfortable after it starts getting cold.
even when I was in a hot cab and sweating (yes this is an odd feeling)
this is compounded by the insulating properties of the foam around the tubes
it seems to focus the cold into narrow uncomfortable channels
if you are using ice water & an 8 loop system it might drive you out of the seat
your leather seats may mitigate some of this
also wondering if smaller tubes (capillary) and more of them might help.
A cold seat (towel) may not be enough-
I have used this seat cover in hot conditions and it is not enough (even when full uncomfortably cold) to keep me anywhere near cool. This cover is only cooling about 2 square feet - but I have to use the air-conditioner as well. In conjunction with A/C it is nice to have a cool seat - without A/C you sweat
not sure I have even turned the A/C down much
just a heads up before you start cutting on your seat
you may want make a cool towel type temporary mockup for a few drives before you commit.
Concrete
Old 08-06-2008, 05:06 AM   #49 (permalink)
Is there a aluminized fabric or another means of spreading the cold more evenly over the entire seat cushion?
This way it wouldn't be like sitting on a frozen branding iron.
I guess you could always throw a beaded seat cushion over it....
Old 08-15-2008, 01:14 AM   #50 (permalink)
Sequential
Concrete's Avatar
Dremd,
hope the Vibe & house is going back together okay
I do have an update from using the cool or heat seat - with a mod
it is not a beaded seat cover though
to prevent the aptly named "frozen branding iron" effect
I covered my seat cover with a piece of cheap vinyl
sort of a faux leather experiment - thought it might help your project
the vinyl does help spread the cool out a bit
it takes longer to cool off (more thermal inertia) but with your design that won't as big an issue as with mine
condensation is still there - but like you said -not as bad as just sweating into seat
still would recommend a set up that you could take back out with out damage for initial development
looking forward to how it turns out
I might hack this seat cover into a "Dremd-like" concept next summer if you get something you like
Concrete
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 03:30 AM
Beaded Seat Covers Are Cheap, Keep You Cool SVOboy EcoModder Blog Discussion 48 03-02-2009 04:15 PM
Do Metros have back seat belts & do child seats need to be installed on a seat Wayneburg General Efficiency Discussion 8 05-07-2008 02:11 PM
Budget chevy lumina project. ihatejoefitz Introductions 4 04-19-2008 07:41 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
