Old 04-21-2009, 11:24 PM   #61 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 Chevy S10 Extended Cab
90 day: 22.47 mpg (US)
Dremd,
glad to hear you are back on the case
interested to see the progress
I like the copper tubing idea
Concrete
Start where you are - Use what you have - Do what you can.
Old 05-01-2009, 01:10 PM   #62 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Just found another pump Idea.
DC 12V mini water pump(centrifugal pump)38-03 - eBay (item 260294009674 end time May-28-09 01:26:11 PDT)
Now I'm considering using an Ice Chest and multiple pumps.
So I'd have a pump for each seat; and one for the cooling circuit (to the A/C) that way I could Pulse and glide the crap out of it; BUT then I'd have a slow start up . . . May be some valving would fix that; OR maybe a T inlet to the seat pumps with 1 T leg on the tank and the other to the A/C return loop.
Ice chest http://www.nothingbuthardware.com/808687.html
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 05-01-2009, 04:11 PM   #63 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Originally Posted by dremd View Post
Can anybody think of a small cheap radiator that might fit in my A/C duct?
Or should I just try and wrap some copper tubing around the return line?
Water cooled PC radiator
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 05-01-2009, 10:39 PM   #64 (permalink)
Sequential
Concrete's Avatar
I would start with a simple AC loop - you can always add to the system later
and you may be surprised by the thermal inertia of just the water in the tubes
Concrete
Old 05-08-2009, 06:18 PM   #65 (permalink)
EV OR DIESEL
Looks like This project is going to have to be put back another week.
Going to work on http://ecomodder.com/forum/showthrea...-tdi-8290.html.
But I did gather up 4 of these
and Drilled them all out to maximize flow.
Edit:
Now all I need to find is a pair of Threaded Plastic 1/2" NPT T's. and maybe a little more 3/4" clear tube.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 06-03-2009, 03:51 PM   #66 (permalink)
EV OR DIESEL
Just received a bad pump err . . . .
On the lookout for new pump.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 06-04-2009, 12:10 PM   #67 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
You can get 1/8" o.d. copper & aluminum tubing for the a/c duct thing.
If you put the Paltier (sp) device in the trunk the heat can go there. Good insulation on the tubing will get more "cool" to your seat. If you have one of those electric coolers, which I think is a paltier device, You could put ice in it & turn on the cooling when the ice water gets too warm.
After looking at new cars with cooled seats, air pumped through perforated leather upholstery. You could take 2 sheets of suede, 1 perferated & one not, & sewed them together with serpentine quilting. Pumping air through the pad would keep the nether region cool. The cooler the air the cooler your chair. Small cooler would still apply.
Don
Old 06-04-2009, 12:42 PM   #68 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
You could take DonR's thoughts to the bank. You would have to modify the cooler, like cut a hole in the side and mount the Peltier in the side or floor of the cooler and silicone around it to seal it, then insulate or even better, heatsink the other side. Check out the rather large one here:
Gigantic 62mm - 545 Watt Thermoelectric Peltier Cooler - eBay (item 310104062553 end time Jun-24-09 15:45:03 PDT)
That would be a good solution, however, you will want to have something that moves the water around inside the cooler, like a propeller. Otherwise you may freeze the water nearest to the Peltier device. Good luck.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 06-08-2009, 11:36 PM   #69 (permalink)
EV OR DIESEL
New pump on the way.
I'm trying to avoid peltier due to terrible efficiency.
Planning on doing 2 or 4 loops of 1/4" copper to collect cold from the evaporator.
Man I can't wait to get to work on more ecomodder projects.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 07-24-2009, 07:36 PM   #70 (permalink)
EV OR DIESEL
while the car is apart for the wreck (rear ended) I pulled the drivers seat and did this
I also shot a video of the new pump test; works GREAT. I'll post it when I get back home.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
Beaded Seat Covers Are Cheap, Keep You Cool SVOboy EcoModder Blog Discussion 48 03-02-2009 03:15 PM
Do Metros have back seat belts & do child seats need to be installed on a seat Wayneburg General Efficiency Discussion 8 05-07-2008 01:11 PM
Budget chevy lumina project. ihatejoefitz Introductions 4 04-19-2008 06:41 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
