Old 04-19-2018, 03:20 PM   #1 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Steering locked
Hi folks I picked up a 70 Barracuda as a project car there's no key the nice aluminum area where you would put the key in is gone just just a slotted hole in the middle of the inner part and I just need to be able to push the car and in the position in a shop can I just take a big chisel and smash it in do I drill it out I plan on getting a nice tilt column later on but I have another car project in front of this I just want to be able to move it around in the shop steer it like a human being your thoughts please
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 04-19-2018, 05:24 PM   #2 (permalink)
EcoModding Lurcher
mort's Avatar
Hi larrybuck,
With a steering wheel puller, I believe you can pull the steering wheel, and the locking disk is just under the turn signal cam, oh there might be the clock spring in there too. The disk is held on with a split ring and there is a big spring behind the disk. You can pry out the split ring, but the spring may shoot the disk out at your face, so beware.
-mort
The Following 2 Users Say Thank You to mort For This Useful Post:
larrybuck (04-20-2018), Xist (04-19-2018)
Old 04-19-2018, 05:57 PM   #3 (permalink)
larrybuck's Avatar
Thank you Mark for this important tip I actually had to buy the car without a steering wheel I ordered a nice-looking Grant aftermarket which didn't fit surprise surprise so now I've ordered just a plain Jane used one for now off of eBay that should be here in a few days again preciate the help very much
Old 04-19-2018, 05:58 PM   #4 (permalink)
larrybuck's Avatar
Amazing how verbal texting screws up the words I know that you're not mark just saying
Old 04-20-2018, 01:29 AM   #5 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Big floor jack under the front end, drag or push it in to position until you have time to deal with the column properly.
Or just remove the column completely, since its probably only being held on by 3 bolts, and manhandle the tires in to position.
The Following User Says Thank You to Stubby79 For This Useful Post:
Old 04-20-2018, 01:43 AM   #6 (permalink)
larrybuck's Avatar
Turtle
Hey everybody thank you for your information I went totally old school didn't mess with it it's been about three three and a half hours got it out of the trailer pulled it with a chain with another vehicle to get it out carefully use the lawn tractor to get through the gap over the little hump into the garage used tire dollies floor jack little by little you push on the sides and the floor dollies would just go flying after a little bit of movement start over Push Pull but I finally got it exactly where I wanted it
