Old 06-25-2014, 02:01 PM   #61 (permalink)
Originally Posted by pgfpro View Post
12v non-L/B
12v L/B if all parameters are meet
16v non-L/B (there is no 16v L/B)
^^^ this is 100% true for normal operation and with no CEL
However if the O2 sensor is disconnected you will only have the following mode:
12V safe mode(limp mode) which for fuel mapping is different than the 3 above
The Following User Says Thank You to 97-civic-ex For This Useful Post:
pgfpro (06-25-2014)
Old 06-25-2014, 03:08 PM   #62 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I 100% agree!!!
Pressure Gradient Force
The Positive Side of the Number Line
Old 06-25-2014, 03:25 PM   #63 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
12v non-L/B
I disagree. I can/have done it. There are 4 operating modes, not counting dfco, egr, or enrichment.
The window is very limited though, and you need to be drafting/ going downhill/ or have heavy aero mods.
You can also swap to a euro ecu, where the window is larger at higher rpm.
On a 94-95 US ecu I couldn't do unless it was drafting and downhill (smaller window), in that case you'd be better of EOC anyway.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 06-25-2014, 04:12 PM   #64 (permalink)
Not disagreeing with you and this case is way beyond the OP's abilities anyway so we may be going off topic for the question at hand, but are you sure you were not seeing fuel cut? Downhill will enduce fuel cut mode which will look like lean mode on any O2 sensor, wideband, or other such monitoring system. Downhill, coasting/drafting, and/or drastic aeromods will require such little engine load that the ecu would disengage vtec anyway, so are you sure there is a 4th mode? Just curious as to how you did your testing.
Old 06-25-2014, 05:19 PM   #65 (permalink)
mpguino for lb and vacuum for vtec. Also stated by bajoos (don't know if he tried with a us ecu though). You do enough driving over rolling hills you'll get a feel for all 4.
Old 06-25-2014, 07:41 PM   #66 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Can you please explain the 4th mode in more detail?
Old 06-25-2014, 09:14 PM   #67 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
PGFPRO - I was just trying to be funny with the mitsu crack! nothing against the mitsu guys!
with my dual vtec d15b, I can say there are at least 4 operating modes:
12v lean burn
12v standard operation
16v mid cam (vtec1 about 3k rpm)
16v wild cam (dual vtec about5200 rpm)
I'm not running a d15z1 like a lot of you guys-
(jdm ecu 37820-p2j-j62, jdm d15b motor, vx tranny, 4door lx civic)
I want to say XNTRX (hope I spelled that right) said that there was a bunch of combinations of lean burn in 12v and 16v mode, but only within certain windows, as explained in any of the OP's threads (that does not apply to my motor, I'm sure, but I've got a d15z1 in the garage for the next project, so I'm busy learning
I'VE GOT MAD RESPECT FOR ANYBODY BREAKING 40 MPG'S (NON - HYBRID)
-just sayin'
The Following User Says Thank You to vrmouseyd15b For This Useful Post:
pgfpro (06-25-2014)
Old 06-25-2014, 09:30 PM   #68 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
12v lean burn
-just sayin'
Don't worry I never was offended. lol I'm more of a Honda guy then anything else. I still have a VX engine and trans and ecu. Just looking for another VX civic to put it in.
Old 06-25-2014, 09:58 PM   #69 (permalink)
Team "Old SKOOL"
cool.
I'm dreaming of an Integra, or maybe a Prelude (2dr, leather, sunroof either way) for my d15z1 and my vx tranny that I'll be picking up in Cincinatti from fellow ecomodder TURBOVR41991 on sautrday
EDIT:
TURBOVR41991 DOES HAVE ONE MORE VX TRANNY, READY TO GO FOR SALE:
http://ecomodder.com/forum/showthrea...ale-28931.html
