Old 07-30-2015, 01:50 PM   #1 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
SuperMID shows accessory loads on engine
One nice thing about the SuperMID is that it displays the injector pulse width so you can instantly see the effect of various loads on engine fuel consumption. About 5 years ago I published a thread showing the effect of various loads on the injector pulse width for my car when it had a 16 valve non-lean burn engine installed in it.
Here are the figures with the lean burn engine.
SuperMID readings in uSec
Baseline
Idle (600 rpm) on warm engine 1.9
Revving engine to 1000 rpm with no load 1.4
Revving to 2000 rpm " " " 1.7
Revving to 3000 rpm " " " 1.9
(Lean burn kicks in to reduce pulse width above idle)
Idle + parking lights 2.0
Idle + low beams 2.1
Idle + high beams 2.2
When driving at 60mph, I lose 1 to 2 mpg when driving with the low beams on, so at 60 mph I'm losing about 1 mpg for each 0.15 increase in injector pulse width.
Idle + Engine cooling fan 2.1
Idle + Cabin cooling fan on 1 2.0
Idle + cabin cooling fan on 2 2.0
Idle + cabin cooling fan on 3 2.1
Idle + cabin cooling fan on 4 2.2
Idle + a/c + cooling fan on 1 3.8
Idle + a/c + cooling fan on 4 4.0
aerocivic.com
The Following 4 Users Say Thank You to basjoos For This Useful Post:
Fat Charlie (07-31-2015), jeff88 (07-30-2015), JRMichler (07-31-2015), Xist (07-30-2015)
Old 07-30-2015, 06:22 PM   #2 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
This is good info. Just a few questions...
1) What's a uSec? Is that a milli second?
2) Is this with engine up to temp.?
3) I tried searching, but couldn't tell what the difference was between a SuperMID and an MPGuino. Any idea?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 07-30-2015, 10:44 PM   #3 (permalink)
A μSec is a microsecond.
It looks like MetroMpg came up with the idea for the MPGuino, so it is obviously better! I think that the SuperMID has more features, but I am not sure what you would need to do to get your own, while I think the MPGuino is overly complicated.
Just order one from a fine gentleman in Estonia.
Find a nice box
Hack your car
Profit!
I looked into the SuperMID when Basjoos mentioned it before. Yoshi, the guy that makes it, is reclusive, overwhelmingly busy, or something. There do not seem to be very many units in existence, so information is scarce.
jeff88 (07-31-2015)
Old 07-31-2015, 02:49 AM   #4 (permalink)
Send a message via MSN to markweatherill
Isn't 'usec' microseconds? (Milliseconds should be represented by 'ms')
The Following User Says Thank You to markweatherill For This Useful Post:
jeff88 (08-01-2015)
Old 07-31-2015, 07:51 AM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Although MPGuino, SuperMID and UTComp are more accurate, any OBD gauge can also supply you with this info (and some factory computers too). Just set your gauge to watch LPH/GPH, and turn things on/ off.
