Old 11-19-2008, 09:40 AM   #11 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by canhonkey View Post
Anyways, nobody really wrote back if they had any problems with the 98-01 4 cyl metro swap onto a G10..so I will if I don't hear back.
No problems. Other than I had a little trouble getting the replacement trans input shaft onto the clutch hub on the flywheel. (I left the motor in the car to do the swap - it moved around a lot while I was wiggling the trans home.)
In case you haven't seen them:
Metro taller tranny swap thread: +5% efficiency gain - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
Project 'nerd gear': taller tranny transplant nets +5.2% MPG - MetroMPG.com
Old 11-19-2008, 09:42 AM   #12 (permalink)
Oh - I also had to re-adjust the clutch cable for some reason when I was done.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
transmission determination - how to determine final drive ratio? gwahir EcoModding Central 8 09-19-2014 02:42 AM
The Suzuki Swift is still a super sweet car! SVOboy General Efficiency Discussion 15 11-22-2009 11:17 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
My auto transmission is clunky! Help! bennelson Off-Topic Tech 6 03-14-2008 05:50 PM
