Old 03-09-2009, 02:57 PM   #21 (permalink)
AFAIK, a pointy cigar is the optimal shape for a given volume with airflow parallel to the object. The only reason a rounded front is better is to be able to handle flow at an angle.
That's why the hulls of ships are cigar shaped with a pointy front and back.
Old 03-09-2009, 03:04 PM   #22 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Old 03-09-2009, 03:22 PM   #23 (permalink)
Here is something interesting.. The optimal shapes for holding pressure in a submarine are cylinders and hemispheres. But that is not the best for drag, so submarines used to be designed with an external hull that wasn't sealed, and it would be pointy on both ends.
submarine: Definition from Answers.com
Old 03-09-2009, 04:04 PM   #24 (permalink)
90 day: 51.82 mpg (US)
Ships (and some subs) need pointy bows for reasons other than drag. (Hint: think waves.)
Note that the part of a ship which works at the air/water boundary (ie. where there are waves) is generally pointy, but if it has a fully submerged drag reducing bulb, it is well, bulbous.
Old 03-09-2009, 04:18 PM   #25 (permalink)
The purpose of the bulb is to change the shape of the bow wave so it doesn't interfere with hydrodynamics at the rear of the ship. It's optimized for a particular speed
Bulbous Bow
Old 03-09-2009, 04:29 PM   #26 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
You can't confuse hydrodynamics and aerodynamics. They work pretty differently. We're not trying to pull your leg here. Simply google "lowest cd shape" and you'll find a million references to an airfoil (aka teardrop). Dig deeper and you'll see why the bulb is better than a flat front or a pointy front. Better yet, search around this site. This dead horse has been beaten into a unrecognisable bloody spatter.
Old 03-09-2009, 04:32 PM   #27 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
I like to save this for special occasions:
Old 03-09-2009, 05:05 PM   #28 (permalink)
The only way that I can see how a round front is "better" than a pointy front are the other non-aerodynamic reasons for having a short overhang.
Those pictures Piwoslaw posted very clearly show better airflow under the nose. The pink stream quickly reattaches, and stays attached the entire length of the underside, while the pink line under the semi round front is destroyed and never reforms.
I would also bet that barometers placed at the nose would show better, lower readings in front of a pointy nose.
I am also inclined not to think that the engineers of Porsche, Ferrari, McClaren, Mercedes, Audi, etc. are completely clueless.
Old 03-09-2009, 05:23 PM   #29 (permalink)
And why do all the fast fish have pointy noses AND pointy tails?
Old 03-09-2009, 05:28 PM   #30 (permalink)
I mean seriously, don't those noobs over at Aptera realize that their design would be more efficient with a hemispherical nose? LOL
Index of Phil Knox Aerodynamics Seminars & Mod-data lists TestDrive Aerodynamics 21 11-21-2022 09:57 AM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 7 08-08-2012 06:00 PM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
