09-08-2019, 07:22 PM
#11 (permalink)
Installed a vacuum gauge today.
Big, Heavy & Slow - The Purple People Eater 4x4
09-09-2019, 05:31 PM
#12 (permalink)
Put less than 20 miles on the clock since installing the vacuum gauge and filled up on my way home from work. I managed 23.3 MPG this tank.
09-10-2019, 07:23 AM
#13 (permalink)
Master Novice
Looks like a pretty good choice for hypermiling!
Trucks, especially the older ones, get virtually no consideration around aerodynamics. There's a huge array of things you can do that should all pay off, and due to how trucks are made they're generally easier to install. Things are complicated slightly by the fact that what you install is also generally bigger.
The Following User Says Thank You to elhigh For This Useful Post:
09-10-2019, 07:47 PM
#14 (permalink)
That's a good point, plus even a small improvement is proportionately higher in a truck compared to some smaller, lighter, more aerodynamic and inherently more efficient car.
A good old body-on-frame layout may have its drawbacks, but if you wouldn't be willing to keep your vehicle looking mostly stock it still allows you to go extreme without so much risk of compromising the structural integrity.
09-11-2019, 12:52 PM
#15 (permalink)
Thanks, I hope to build a tonneau cover next
09-11-2019, 12:59 PM
#16 (permalink)
I'm defiantly keeping it looking mostly stock - not even going as far as an aerocover or wheel skirts; I may do wheel covers and a skid plate.
09-11-2019, 09:54 PM
#17 (permalink)
Rat Racer
You're doing great! Sure, the numbers suck but the percentage gain is awesome.
An air dam and belly pan should help while looking stock.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
09-13-2019, 12:26 AM
#18 (permalink)
I'm usually also more favorable to a cleaner, stock look, but would probably feel tempted to try some discrete aerodynamic improvements and lower-weight materials.
