Old 03-30-2013, 11:56 AM   #71 (permalink)
It appears the spoiler is mounted too far forward. I would look at putting it on the radius of the trunk at a shallow angle. Some work under the trunk might help as well.
Old 03-30-2013, 12:56 PM   #72 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
The pics are not from falcon. It doesn't seem to work right for me. Maybe there is an update or something. I have been using flow illustrator.
I will be installing a belly pan, so the bottom will be fine. I think just taking the spoiler off will give some good results. I will tuft/streamer test to find out. 6-8 feet of yarn should work nicely.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 03-31-2013, 01:18 PM   #73 (permalink)
Eco Sol
Shortie771's Avatar
Agreed. Raised spoilers are a waste. Mostly just good for drag and downforce. Conservative drivers that arent going 200+mph need neither.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 03-31-2013, 03:09 PM   #74 (permalink)
Aerodynamically generated downforce (and associated drag) can be felt in my pick-up truck (spoiler fitted) at as low as 35 MPH.
I don't need to attempt a 200 MPH run on a salt flat to appreciate the extra downforce and therefore safety this brings me on the street.
On a winding road which is wet and cold, going 45 MPH is much less of a traumatic event for me. That extra level of safety does wonders for my stress levels.
Old 04-03-2013, 10:53 PM   #75 (permalink)
gil
gil's Avatar
The Drift - '85 Toyota Corolla GTS
90 day: 28.26 mpg (US)
!Rally - '02 Subaru Impreza WRX
90 day: 27.68 mpg (US)
Cinnamon - '13 Honda PCX 150
90 day: 75.86 mpg (US)
I got some cool results from Autodesk Project Falcon.
I downloaded a model of my car from Google sketch Up and cleaned it up a bit, not perfect. The Stock Drag Coefficient, that I could find online, for the 1985 Toyota Corolla GTS was a .39 CD. The Result from Falcon was .49 CD. I think one of the plausible disparities in the numbers is the Inaccurate 3D model of the Corolla, like the head lights up, mudflaps that are too wide and the thick antenna besides other details. The result is exiting non-the less.
Old 04-03-2013, 11:03 PM   #76 (permalink)
gil
gil's Avatar
The Resulting CD stabilized after six hrs of it running.
Falcon-ae864 | Flickr - Photo Sharing!
Old 09-03-2013, 08:08 PM   #77 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Is everyone else having success with Falcon ? So far my copy is still going strong, despite "expiring" several days ago.
I have run a model of a first generation Insight and it returned a .25 Cd, as well as a model of a Karmann Ghia ( thanks Neil ! ) that returned a .48 Cd after an hour and a half render time.
Old 09-04-2013, 05:22 PM   #78 (permalink)
KG
The actual Cd of the Ghia is 0.39.
Cd (09-04-2013)
Old 09-04-2013, 08:31 PM   #79 (permalink)
As I mentioned, that model of the Karmann Ghia has large voids on the underside.
Old 09-15-2013, 09:40 AM   #80 (permalink)
cfdguy - '13 VW Golf TDI
I saw only one guy using OpenFOAM. Everybody on here should be using it. If Falcon solves the cases that quickly, it cannot be that accurate. The models need to have a proper surface mesh created and then the fluid region needs to have a good mesh. Just to mesh the car with say a quality mesher will take around 5-10 minutes (this is to say with less than or equal to 5 million cells). With snappyHexMesh in OpenFOAM it will take significantly longer (around 1 hr running in parallel for 5 million cells if i remember correctly). If you all were using OpenFOAM, you could share case files to get everything set up. I can help anybody out if need be. You can also get a Windows version of OpenFOAM from blueCape or something like that. It is very cheap.
I am planning on running cfd on my new golf using OpenFOAM. I will post more when I get the cfd model ready.
The Following User Says Thank You to cfd_guy For This Useful Post:
Cd (09-15-2013)
