07-15-2015, 09:33 AM
#41 (permalink)
The lowest rolling resistance tires I know of are the Bridgestone Ecopia EP422 205/55 16's and the Nokian Hakka R2 winter tires.
07-15-2015, 11:22 PM
#42 (permalink)
freshly uglified
And here it is with coro discs hiding the sexy wheels...
Those RE92's should go even further now.
07-16-2015, 02:41 AM
#43 (permalink)
Too many cars
Now put photos of the wheels on the covers!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
07-16-2015, 02:47 PM
#44 (permalink)
Lean Burn Cruiser!
I'm curious as to how you're go to wheel disc are so round. How do you do it?! Mine are more like a decagon
07-16-2015, 04:57 PM
#45 (permalink)
A pin-hole in the center back would be sufficient.
I've always like this Metro. The black on fenderskirts, I think. Murder out the caps?
07-16-2015, 05:19 PM
#46 (permalink)
I actually considered going with black discs, but I don't want to be driving a nearly invisible tiny car.  The white disc look is growing on me.
BabyDiesel: that's what I did -- a pinhole in the back to trace out the circle. Then a big pair of sharp scissors.
08-12-2015, 12:19 PM
#47 (permalink)
Raggamuffin
I have recently had to replace the tires on my new to me '07 Civic, went with the Bridgestone Ecopia Plus 422EP. I believe I'm seeing 2-4 MPG improvement from the older Uniroyal Tigerpaws that were on it.
The Following 2 Users Say Thank You to Xusn96 For This Useful Post:
08-13-2015, 02:56 PM
#48 (permalink)
RE92 driving characteristics?
I got this private message; I want to share it in the forum since I may not have the best perspective...
I noticed you tested Bridgestone RE92 tires and they had the best rolling resistance. I've been reading reviews on them and they are less than spectacular. Did you have these for a length of time where you can comment on thread-wear, traction, and corning? I usually take my corners pretty fast upwards of 45mph but the reviews say corning is terrible which I guess makes sense if they have the least amount of resistance. Sorry for the long message. Thanks for any info.
I drove on these for ~2 years on the Insight, and currently have some on my Firefly as well.
I didn't really pay attention to treadwear -- I drive so little that my tires typically dry rot before they're all worn out. But you can probably find info about that on Insight Central if you search.
I disagree that cornering grip is "terrible". The Insight was a decent handling car, and I rarely burned momentum needlessly by braking too much before the curves. In general I probably corner at above average speeds, but to keep my comments in context you have to understand where I'm coming from: most of my driving has been on 155/80R13's the past 10 years.
Anybody else want to chip in?
08-13-2015, 03:01 PM
#49 (permalink)
OH: I should add the PM'er may be driving a Camry, which if true changes things. Because the RE92 is only LRR in the 165/65r14 size if I'm not mistaken. The other sizes of "RE92" are quite different tires.
08-13-2015, 03:03 PM
#50 (permalink)
When I REPLACED the Re92s on my Insight, my mileage did not change at all. When I replaced the ORIGINAL Bridgestone tires on my VX, which were 15 years old, with Michelin Xs that I paid $220 for installed and warrantied, the mileage dropped by 7 mpg. I think they (the originals) were B382s or something like that.
regards
mech
