Old 05-31-2010, 11:54 AM   #1 (permalink)
Ford Escort Hypermiler
WA1DH's Avatar
Doug's Scort - '99 Ford Escort LX
Last 3: 35.21 mpg (US)
Doug's XS650 - '79 Yamaha XS650 Special
90 day: 50.91 mpg (US)
Send a message via AIM to WA1DH Send a message via Yahoo to WA1DH
Tire size and MPG
I have a Ford Escort with P175-65R14 tires on it. 3 of them are worn out, so I'm probably going to be buying a set of 4 for it. I also found out my stock tire size is P185-65R14. Running the 175s has made the speedometer/odometer off by about 2%.
So, my question is, if I go back to the stock 185s, will I notice any difference in MPG? I realize there is more tire on the ground (~.35" wider tread) which means increased rolling resistance. But, will it be enough to notice? I get about 35 MPG highway right now and would like to keep it that way.
Thanks.
Old 05-31-2010, 01:01 PM   #2 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
does your 35 mpg figure factor in the difference in tire size? Generally a longer legged tranny/bigger tires means worse acceleration, better top end, either way, more info needed.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 05-31-2010, 01:36 PM   #3 (permalink)
WA1DH's Avatar
Average of last 10 fills = 36.67 MPG
Corrected for odometer error (2.2%) = 35.86 MPG
Old 05-31-2010, 06:45 PM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
Differences between tires are going to have much more of an affect than tire size will - so choose carefully. Just be aware that there is a technology triangle between rolling resistance, treadwear, and traction (especially wet traction).
Old 05-31-2010, 06:49 PM   #5 (permalink)
And your mpg will probably drop with the new tires, as the old worn-out ones will have the lowest rr.
Old 05-31-2010, 10:36 PM   #6 (permalink)
Good advice.
I don't think it will affect your fuel economy much, if at all. Why not stick with the size originally specified for the vehicle? At least that way your speedometer and odometer will read correctly.
Personally, what I look for in a tire is the best wet traction available and good tread wear. On dry pavement even bald tires will work. On wet pavement it's a whole 'nother ball game, as it may save you from being involved in a crash. To me having the optimal advantage in bad weather is worth more than the few cents saved in fuel.
"Always buy the best. You'll never be disappointed."
Old 05-31-2010, 10:47 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
WA1DH -
I agree with Thymeclock's advice. Don't forget to find out how much the new tire weighs in comparison to the current tire you are using.
I am one-size-up from stock. I considered two-sizes-up from stock, but whereas one-size-up added maybe 1 or 2 lbs per tire, two-sizes-up added maybe 4 lbs. Bigger tire sizes make all your gears taller by x%, but heavier tires increase the load on the engine during acceleration (right guyz?!?!?!).
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
mcrews (06-01-2010)
Old 06-01-2010, 07:42 AM   #8 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by cfg83 View Post
WA1DH -
CarloSW2
I run one up also (way to go CarloSW2!!)
255/45/18 instead of 245/45/18 on stock rims.
It's worth 3.4% to me on the Q45.
And cfg83 is correct, there is a dimishing return due to the added weight. When a tire is rolling the static weight 1-2lbs is now X 4. 4-8lbs per wheel. THis can dramaticly increase the wear and tear on the other componets ...brake parts.....bushings etc......
In my case, since I drive on the freeway for 65% of my 40k a yr, the up size is VERY much a win for me due to the lower rpm at 55mph.
If I was just doing intown.....I'd probably still do it.
and as far as the speedo being correct....
I JUST LOVE!!!!!! multipling my mileage times 1.034 to get my TRUE MPG!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-01-2010, 08:45 PM   #9 (permalink)
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
LRR is important...
Its real easy to lose 1-2mpg when buying new "sticky" tires.
I totally agree with the post regarding wet traction. In my 30+ yrs of driving most of my accidents, especially in my younger days, happened in the rain or snow. Dry traction isn't really a issue unless your racing.
Take a look at the Yokohama Avid Touring tires. Inexpensive, good wet traction and decently good rolling resistance. Good LRR if you over inflate into the 40's up to limit of 51 lbs. I am currently riding on 45lbs front, 40lbs back. The tires only bulge slightly and with the 45/40 setup they bulge the same front and back. They are 6.3% oversized. Stock was 195/70-14, using 205/70-15's. Lowered my RPM's almost 200 rpm at 75 mph.
Wheel/tire setup is slightly heavier but it dont feel it with the 5 speed manual tranny.
As for added wear and tear and drive train, its a 2000 Camry and virtually indestructible.
I figure the added wear on tranny and axles is easily offset by the reduction in rpms/engine life. I do like 95% interstate driving and hyper mile all my local driving anyway.
Gained a whole inch of ground clearance on the Camry. I can drive right over most normal sized curbs now if i need too!
Added hieght makes my need for underbelly pan and front air dam even more important to get done. "I need more time C'ptain,"
Mounted them tires myself with a crowbar and Stanley Wonder Bar.
Need to get someone to edit the video clips doing it.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
Old 06-02-2010, 12:32 AM   #10 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
a 99 escort has plenty of engine...
you may be able to go even bigger, if clutch, body, suspension can handle it.
also the 185 going on the same rim will be taller, more than wider.. the width of rim did not change, the tire did.. on the same skinny rim.
40 + mpg out of a mid size truck? phonebootheater EcoModding Central 118 03-26-2014 10:55 PM
Canada's top fuel efficient cars (by class) for 2010 MetroMPG General Efficiency Discussion 3 05-09-2011 01:56 AM
MPG calculation with non-stock tire size? AeroModder EcoModding Central 6 04-03-2010 10:33 PM
tire size (Does ScanGauge have adjustment for different sizes) mcrews Instrumentation 2 12-15-2009 11:29 AM
Tire Size (width) impact on MPG SirKeats EcoModding Central 5 10-31-2009 08:33 AM
