Old 10-27-2011, 06:32 PM   #11 (permalink)
OurInsight - '06 Honda Insight
If you like, email me the .MOV file and I'll post it on EcoModder's YouTube channel. darin@ecomodder.com
I'll give that a try. Fingers crossed
Old 10-27-2011, 09:22 PM   #12 (permalink)
I'll bet the file is (way?) too big for email -- you could try Dropbox?
Uploading to YouTube is easy, though.
Old 10-27-2011, 10:54 PM   #13 (permalink)
Well, it's up on youtube. Neil was right, neither ISP that I use would forward the attached video via email. One service simply said as much, the other just choked and stopped without explanation.
Go to youtube.com and search for "Insight Rear Hatch Tuft Testing," or use this link directly:
http://youtu.be/1s807EGEpWc
I don't have immediate confirmation, but hope this all works out
The Following 5 Users Say Thank You to jime57 For This Useful Post:
Cd (10-30-2011), IamIan (11-01-2011), MetroMPG (10-27-2011), NeilBlanchard (10-28-2011), Piwoslaw (10-28-2011)
Old 10-27-2011, 10:57 PM   #14 (permalink)
90 day: 51.82 mpg (US)
Excellent - thanks for doing that work, Jim!
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (10-29-2011), California98Civic (10-27-2011)
Old 10-27-2011, 11:05 PM   #15 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Very nice. Does the fluttering indicate significant turbulence?
Old 10-27-2011, 11:14 PM   #16 (permalink)
OK. It seems to be up and working.
My take is this:
1. The middle row and the bottom row tufts all indicate attached flow, but slightly turbulent.
2. The top row tufts are more turbulent and I think that this is caused by the the airstream "tripping" slightly on the rather large open seam between the hatch and the roof.
3. Honda pushed the very limit with the hatch angle. They probably figured and optimum compromise between aerodynamics, length, and rear visibility.
Just as a guess, one might raise the hatch lid a couple of inches and achieve better aero. In a couple of weeks I'll probably give that a try. All comments very welcome
Old 10-28-2011, 03:06 AM   #17 (permalink)
The front windshield wipers and door mirrors would also be contributing to the turbulence seen. (Assuming they are in place!)
Old 10-28-2011, 07:28 AM   #18 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
Not necessary to re-shoot. See above comment.
Also, you can remove the audio from a clip after it's uploaded to YouTube, if you're still concerned.
or they will do it for you if they feel there is copywrite infringement.
~Mike
Old 10-28-2011, 09:04 AM   #19 (permalink)
It seems to me that the turbulence is very slight. Probably about as good as anywhere else on the car. The tufts are six inches long, so it is kinda inderstandable that they might flutter a bit on the ends.
I have removed the front wiper and the right side mirror, so I'd just guess that we'd see some asymmetry if your explanation were the case.
One other thing I want to do is put tufts somewhere where I know the flow to be extremely good, like middle of the hood, and see how those look. It just might be that tufts need to be shorter, like 4 inches.
I was amazed that the turbulence did not get worse further back on the hatch. I had been conditioned to think that flow deteriorated as one got closer to the rear edge.
All very interesting. Seems Honda got it pretty much right.
Old 10-28-2011, 09:30 AM   #20 (permalink)
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
Looks good! I just ordered my GoPro Motorsports so I'll be able to get some vids later on.
Planning on a boat tail?
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
