Old 03-17-2011, 02:50 AM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Tuneko FleXcap smooth hubcaps for class 8 trucks
Hi,
Tuneko Ltd first innovative product is called FleXcap.
- It is 3 mm thick ABS plastic hubcap which you bend in to Wheels U-groove.
-It does not have any extra parts and can be installed and removed without any tools.
- It is fastest to install and remove from todays hubcap models
- It has holes for brake cooling and to ease the assembly at the same time
- It can be painted to any color
http://www.youtube.com/user/TunekoLt.../0/lqD3pXVmnQc
- Basic white or black ABS version will cost 50$ (asking price)
- Any colored abs version can be manufactured from order. Price will rise on the serial size needed (+10$ for 16 pcs - 0$ for over 500 pcs)
- Chrome or Polykarbonate versions will cost 70$ (asking price)
If you have any questions don`t hesitate to ask
BR,
Vesa Tiainen=Vekke on ecomodder forum .
CEO
Tuneko Ltd
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (03-17-2011), BamZipPow (03-17-2011)
Old 03-17-2011, 03:01 AM   #2 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Nice design. I'm sure one of the big factors when implementing smooth hub caps is the labor to take them off to do repairs. That's a great idea that would save countless man hours.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 03-17-2011, 04:36 AM   #3 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Thanks fer making yer own thread on these...
Are there any companies in Finland/Europe using these yet? Do truckers balance their rims over there? If so, how does this product work around the wheel weights?
From a safety aspect...
What kind of speed testing has been performed with this product?
Can this product be installed incorrectly?
If this product does come off the rim on it's own, what will happen?
What sort of liabilities will yer product carry?
Will this product fail on it's own? What are the signs of failure? Will this product still remain on the rim if one or more tabs break?
Does this product have to have meet specific DOT/SAE requirements over here in the USA?
For example...this company does testing...
http://www.stllabs.com/testing.htm
Old 03-17-2011, 03:24 PM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
-About 100 capsels are running in finland at the moment. Longest have used them for over four months without any problems.
- Only at front wheels. If you have a wheel weight you have two options. Use tape wheel weights like used on passenger cars aluminium wheels. Or to mill room for the weight to the capsel.
Speed only to 100 km/h or 62 mph. Limit for busses in finland. I would say they can take speeds up to 100 MPH easily.
- Only if your rim does not have enough deep U-groove. Minimum is about 5 mm deep groove. When you assemble them to rim you should pull from each hole to make sure its installed correctly. If rim is does not have enough deep U-groove or you have too long wheel nuts capsel will come off too easily. Pulling force about one KG. If capsel is securely on the wheel you need about ten kilos of pulling force to remove the capsel with wrong technigue.
On speed capsel will rotate like any wheel that comes off. This however in more lighter than regular stainless steel hubcaps or its competitors. Basicly that could cause injury or even death in worst case scenary when capsel cuts your throat open. Anyway if you check your car normally like you should do anyway they wont fall off in normal driving conditions.
Should make a poster/stamp where I say that I dont have nothing to do with any injuries with this product. Assembler and the driver is responsible of any accidents etc?
No it can take heat, moisture, sun and cold weathers. Over long time like over 5 years plastic will start to loose its best properties but still it will hold in place.
If there becomes any visible cracks to surface or FleXcap color starts to fade.
-If you lose only one part between those holes yes. If you lose two parts havent tested that but then you should change the capsel as soon as you notice them get broken. Capsel didint lose any part when is was kicked with full force like on the video. Same test was done three times to same capsel with no visible damges. So if you some pieces that hit will be quite massive and your driver will notice it on the drivers seat.
At least in europe there are no rules to hubcaps but I am not sure about the states. My competitors dont mention anything that they fulfills some requirements :/.
Testing Division - Standards Testing Labs - Tire and Wheel Testing Experts
I tried to contact your SEMA but got nou response on my enquery :/.
Old 03-18-2011, 10:07 AM   #5 (permalink)
EcoModding Dilatant
Volvo - '00 Volvo V70 XC AWD SE
90 day: 27.7 mpg (US)
$50 for the vehicle or $50 each?
Old 03-18-2011, 02:16 PM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Asking price 50$ /per piece. I know there is lots of air, but at the moment I dont have that much interest to expand selling to US, because you sew everyone to court so easily... It takes time to find out what kind of papers I have to attach to my capsel just to be sure...
