Old 05-18-2012, 12:23 PM   #21 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vekke View Post
Tomorrow will euromodder powder starts its journey in the mail.
Thanks for that.
I'll swap the oil soon after it arrives.
The oil is almost 13000km old, and I suspect it's diluted with (bio)diesel.
I have one remaining oil test , so I'll use it to check the oil now.
Engine noise sounds harsher than it should.
Old 05-30-2012, 01:53 PM   #22 (permalink)
euromodder's Avatar
The W2S has arrived !
Thanks.
Got to make an appointment to change the oil now.
Old 06-26-2012, 04:55 PM   #23 (permalink)
euromodder's Avatar
Vekke, you seem to have done quite a few mods after putting in the WS2, but have you seen any further improvement ?
After the fill-up on 2012-06-15, I've had the car serviced (new filters all around) and put 1g/L into the oil, so around 1200 ppm by weight.
I've done 600km since the oil change.
There's no noticeable difference in fuel consumption at any speed.
The engine doesn't appear to run smoother or quieter than before with fresh oil.
The good part is that the oil filter to the turbo hasn't gotten clogged with WS2 either
Old 08-12-2012, 03:00 PM   #24 (permalink)
Focus - '05 Ford Focus tdci Futura
Any more info on the stuff???
Old 08-13-2012, 05:55 PM   #25 (permalink)
euromodder's Avatar
My mileage is getting better, but that's likely attributed to improved driving technique rather than the WS2.
It's been over 4000 km since I added it.
Surely it can't take that long to start having an effect ?
Old 08-14-2012, 05:24 PM   #26 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I cannot say the positive effects to my car are made alone by that powder. I ordered second set of powder and will put it to other cars as well. Next weeked will get second Lupo 3L treatment to engine and transmission and that is a regular car.
On my car the effect in coasting distances was immediate, but that was with heavy amount of powder. Also what I have heard from my friends the effects should be immediate if your oils are saving any fuel. However with this product they claim that it "coats" the surfaces during time.
I just made second oil change with powder in engine oil and no negative effects even though I am using again that 2.5 times ratio that is recommended. If you search the internet there are already few companies that sell that kind of engine oils.
Nano-based lubricant from Millers Oils: potential fuel saver on track and road
They dont say what is the secret material but I could make small guess what they are using...
http://www.orapinordic.net/nano2021_fin.pdf
That chart is with various mixture percentages 3 different oils. It seems after 2.5% of that nano fluid the performance stays at same level...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 08-14-2012, 05:46 PM   #27 (permalink)
Diabla - '09 Renault Laguna Hatchback
euromodder and Vekke: What about idle consumption in litres per hour, has it changed measurably?
I think that is one of the most certain numbers with a warmed up engine, maybe even measuring 2 or 3000rpm in neutral, everything else is prone to oscillate due to other variables.
Old 08-14-2012, 07:04 PM   #28 (permalink)
euromodder's Avatar
Not really.
It's still 0,5 L/h
As I don't have a L/h indication, it's derived from 0,5 L/100km @ 100kph while coasting in neutral.
It's subjective, but the engine does seem to run smoother / more quiet though.
I only have the tungsten in the engine oil, so coasting distance is not affected.
Old 08-15-2012, 03:07 PM   #29 (permalink)
I wil look into it here in the netherlands. Have to change oil here, its been abouth 50.000 km since last change. And maybe drop it in de gearbox to.
Old 08-18-2012, 05:38 AM   #30 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
for idle fuel consumption measuring you need better meters than the cars own. So some kind of datalogger to CAN like vag com. difference between 0.5 and 0.4 liter per hour is huge...
Today I will change my rear wheel bearings and take oem grease out and put redline bearing grease and add ws2.
friction, lower, tungsten disulfide, ws2
